Piston wrist pin
Old Aug 8, 2017 | 08:57 PM
  #31
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Here's a thread that goes into some planning and should give some ideas.
https://www.f150forum.com/f10/bit-in...l-302s-276512/
Still doesn't address quench or dynamic compression ratio, etc. A lot more information toward the "parts swapping" end of things and not much toward the engineering end of things.
Old Aug 8, 2017 | 09:53 PM
  #32
HardScrabble
This looks like a real good thread but I'll have to finish reading it later. Done for tonight.
https://www.ford-trucks.com/forums/1...-upgrades.html
More future reading:
https://www.ford-trucks.com/forums/5...re-better.html
https://www.ford-trucks.com/forums/5...stock-cam.html
Old Aug 8, 2017 | 09:55 PM
  #33
GoinBoarding's Avatar
GoinBoarding
Those are good reads.
I covered some of this (quench) in my 5.8L Budget Build thread last fall; or at least I think I did? Might be worth a skim read. Spoiler; no dynamic compression planning; I just swapped recommended parts there. https://www.ford-trucks.com/forums/1...et-minded.html
Stock head gasket was 0.039", 4.100" bore, with E7's CC measured at 64cc and stock 351W pistons zero decked with 20cc dish, for a compression ratio of 8.8:1. Going over 0.050" squish is not advised, as the quenching effect falls off especially over 0.060" squish best I can recall. I'd make sure the block is trued up & zero deck it, pick your heads CC size (or mill stock heads a little--but watch CC volume!) and then use piston dish/flattop/dome to dial in the compression ratio around a stock-ish squish between 0.039" and 0.045". Contrary to what may seem intuitive, a loose squish can actually promote detonation. Check out my thread "Post-Mortem analysis" to see the result of 8.3:1 351W running pump gas with the pistons 0.070" in the hole and 0.050 head gaskets. https://www.ford-trucks.com/forums/1...-analysis.html
Old Aug 8, 2017 | 10:24 PM
  #34
'89F2urd's Avatar
'89F2urd
I always run cometic .030 thick 4.06 bore mls gasket on a factory build with an uncut block deck. The factory hg is unnecessary large in all ways.
Old Aug 9, 2017 | 08:57 AM
  #35
HardScrabble
Dynamic compression is a good topic. Low RPM motors can have detonation issues cause you're packing in the maximum charge at low rpm and the engine is under a load, towing, whatever. Engine builders can tweak the cam specs to reduce detonation. It is counter-intuitive. They go the other way with the specs. More cam to lessen the charge at low rpm to reduce detonation. I think they use overlap but overlap might not be right. I remember it's backward of what I would think. Custom cams are cheaper than people think and can work around some other issues like this.
Old Aug 9, 2017 | 09:00 AM
  #36
HardScrabble
One thread talked about Cometic making any thickness head gasket you want. They can also make the squish band any bore size. One thread said a bore matched squish band can reduce detonation. New one on me.
Old Aug 10, 2017 | 08:15 AM
  #37
'89F2urd's Avatar
'89F2urd
The cylinder deck creates a sharp edge that will generate a hot spot (just like any sharp edge in the cc) which an oversized hg exaggerates. Tight bore means it minimizes that hot spot created by the deck. Normally a sharp edge would just be chamfered.
cleatus12r
23
Jun 23, 2019 03:14 PM
Jarkill
Sep 26, 2016 05:43 PM
F-1
19
Jun 7, 2016 10:14 AM
nickt34
Apr 18, 2015 06:57 PM
lenny1carl
Nov 28, 2006 09:54 AM
