Drove my 2003 F-350 7.3 in the barn to work on hubs. When I went to take it out for a test run, Nothing.
Nothing as in no start . no click, radio reset, lights work. When I checked bats got around 13.1 volts..
I had to replace the switch (white plastic thing) few months ago.
The solenoid (on the starter?) may have died. If the headlights dim when you try to start that means the solenoid is engaging and trying to turn the starter.
Only thing diming is the milage gaugeon cluster. All else acts normal when starting.
Is the solonoid on top by the glow plug one??
Could the ignition switch actuator be bad??
