Sponsored by: Real Truck
Help Again
Old Aug 4, 2017 | 06:17 PM
Jterr's Avatar
Jterr
Help Again
Drove my 2003 F-350 7.3 in the barn to work on hubs. When I went to take it out for a test run, Nothing.
Nothing as in no start . no click, radio reset, lights work. When I checked bats got around 13.1 volts..
I had to replace the switch (white plastic thing) few months ago.
Where should I start checking??
Old Aug 4, 2017 | 07:45 PM
thomabb's Avatar
thomabb
Does the radio go dark when you try to crank? Do the headlights dim?
Old Aug 4, 2017 | 08:37 PM
Jterr's Avatar
Jterr
the milege gauge goes blank didn't notice radio and was by myself so not sure on lights.
Maybe have to check Sat when I have help
Old Aug 5, 2017 | 05:44 AM
DogRidesInBack's Avatar
DogRidesInBack
Stupid question... Assuming the battery is good and everything else works but turning the key still does not do anything...
Are you sure the truck is in park or neutral?
Old Aug 5, 2017 | 05:53 AM
petrokiller's Avatar
petrokiller
Same as Dogridesinback suggest.
Try making sure that the truck shifter is in park.
Old Aug 5, 2017 | 07:33 AM
thomabb's Avatar
thomabb
The solenoid (on the starter?) may have died. If the headlights dim when you try to start that means the solenoid is engaging and trying to turn the starter.
Old Aug 5, 2017 | 01:45 PM
Jterr's Avatar
Jterr
Only thing diming is the milage gaugeon cluster. All else acts normal when starting.
Is the solonoid on top by the glow plug one??
Could the ignition switch actuator be bad??
Old Aug 5, 2017 | 06:34 PM
Jterr's Avatar
Jterr
Got it was the Ignition switch I put in last year-parts you get these days suck.
It was a BWD part
WWR
2004 - 2008 F150
Jun 9, 2017 10:50 AM
Frantz
Apr 22, 2017 10:19 AM
dcelrod
Aug 24, 2015 12:26 PM
parrishjoh
Electrical Systems/Wiring
Mar 1, 2011 04:49 PM
chaseface84
Apr 30, 2004 02:04 PM
