need some help with my 76 stepside!
Old Aug 4, 2017 | 06:12 PM
nates 76 f100's Avatar
nates 76 f100
So what I'm wanting to do with my truck is convert it to a dually with 1 ton axles that I can get super cheap. right now I have a mild built 390 with a manual 4 speed with granny. 9 inch rear with Detroit lockers front and rear. I wanted a dually to make it one of a kind and personally I think it would be awesome.
I'm also considering making the 390 a stroker to a 445 with a 150 shot of nitrous for a little extra go when I hit the mud. if anyone could help me with the front axle set up that would be great.
Old Aug 8, 2017 | 05:58 AM
stevenconrad66's Avatar
stevenconrad66
10.25 sterling and try to find a king pin 60 for up front. Honestly id keep the 9 and im guessing 44 you have now. Yaint gonna break a 9 and ill be damned if you ****ed up the front guy seeing as youve given it new guts. Id wager if anything youd break the detroit before a shaft. As for the giggle gas check out the kits by edelbrock. Last i knew it was around 650 for everything but 10lbs of gas.
ford 801
28
Sep 29, 2015 03:30 AM
60f100streetmacv
13
Mar 15, 2011 12:05 PM
mjl351w
Offroad & 4x4
18
Dec 13, 2004 09:55 PM
dinosaurfan
26
Nov 23, 2003 07:32 PM
big88b2
1978 - 1996 Big Bronco
May 6, 2003 09:02 AM
