Leveling kit
Old Aug 4, 2017 | 06:41 AM
Tor's Avatar
Tor
Leveling kit
I'm now looking at spacer kits, as I'm told all the coil spring lifts available are for diesels, and none of the manufacturers know how much they will lift a gas truck, best guess was 3-3.5", and I'm thinking that may be too high. Anyway, the spacer kits come with a rubber buffer to reduce noise because the spacer is not bolted down like on Dodge. Has anyone had trouble with noise/ squeaking or the rubber wearing out?
Old Aug 4, 2017 | 07:01 AM
shaneinga's Avatar
shaneinga
I have never heard mine squeak.
Old Aug 4, 2017 | 07:17 AM
RugbyRef's Avatar
RugbyRef
Likewise...I've had spacer kits to level my vehicles in the past and never heard a squeak outa them.
Old Aug 4, 2017 | 08:02 AM
Tor's Avatar
Tor
Thanks guys, did you install track and sway bar brackets and castor shims as well?
Old Aug 4, 2017 | 09:17 AM
shaneinga's Avatar
shaneinga
IDK, I took mine to my local 4 Wheel drive parts store, told them I wanted it leveled. They installed the leveling kit with everything needed to make it ride right. Mine drives damn near like stock.
Old Aug 4, 2017 | 09:58 AM
RugbyRef's Avatar
RugbyRef
I did not, but that was many years ago before really anyone knew you had to do that. Literally, it was a couple of pucks and associated hardware. I believe most leveling kits snow offer track bar brackets and caster shims however.
Tim
96sherm
2009 - 2014 F150
30
Oct 19, 2012 09:53 PM
LaredoF350
Apr 27, 2009 09:30 AM
04heritage4.2
Oct 2, 2005 11:55 PM
chadrock
2004 - 2008 F150
Jun 3, 2004 08:32 PM
