Sponsored by: Real Truck
V10 transmission question
Old Aug 3, 2017 | 05:13 PM
Leonx350's Avatar
Leonx350
I just recently picked up a 99 F350 V10 needing a transmission. I found a rebuilt 4r100 from a 01 5.4 as a replacement. When I went to drop the V10 transmission and put it side by side to compare with the replacement I noticed the V10 didn't have the tcc/oss sensors on top as did the 5.4. It looks like itll still bolt up but I'm not sure if itll work since theres nothing to plug into those sensors. Any one else ever run into this issue?
Old Aug 3, 2017 | 05:20 PM
Mike189677's Avatar
Mike189677
Sounds like your 99 is an early 99 v10 you need a trans from another early 99 v10 the trans from a 5.4 has isnt as strong. The trans from that 01 will not shift right either.
https://www.ford-trucks.com/forums/1...atibility.html
Old Aug 3, 2017 | 05:26 PM
Leonx350's Avatar
Leonx350
Build date on the sticker shows 04/99 so I'm assuming that's a later 99 based on what Ive read.
Old Aug 3, 2017 | 05:43 PM
Mike189677's Avatar
Mike189677
Normally but there are some trucks that were built after the 3/1/99 changeover date have still had the earlier build caricaturists and the trans not having the sensors on top point to this being the case. There is a tag on the trans that has a date see what that is.
Old Aug 3, 2017 | 05:51 PM
Leonx350's Avatar
Leonx350
I don't see any dates on the tag. Just looks like this
3S xc3p-ea
prb-as
00039775
bd-9d05
9592 00039775 4 x 4
** I looked up how to define the date so if I did that correctly the transmission should be from Dec 99
Old Aug 3, 2017 | 08:55 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It isn't an issue. Just ignore the sensors, the PCM in your truck doesn't need them.
The bigger issue is that a V10 will tear up a 5.4L transmission in short order.
The trans will shift fine, for as long as it lasts. The torque converter lockup will be VERY harsh, though.
Old Aug 4, 2017 | 09:45 AM
Leonx350's Avatar
Leonx350
whats the difference in a 4r100 off of a 5.4 vs a 6.8?
Old Aug 4, 2017 | 10:28 AM
Mark Kovalsky
The number of plates in the clutches. The 6.8L trans has more clutch plates, therefore more torque capacity.
1999v10f250
Sep 3, 2018 03:22 PM
bpete
Apr 14, 2018 08:32 PM
blueteam
Aug 29, 2015 08:20 PM
CircleV
Modular V10 (6.8l)
Jan 31, 2004 05:10 PM
