P304ever, coolant in coils?
So I had a lean code and a misfire in cylinder 3 I replaced all the pcv hoses and intake manifold now the misfire is in cylinder 4. I spilled a little coolant in the cylinder 4 spark plug hole yesterday(spark plug still in there luckily) when switching out the coil and injector so I got a two part question.
What else could be causing the misfire. It recently changed from 3 to 4 when I put it back together after doing my intake manifold and gasket so I don't feel like it'll be lost compression.
Secondly what issues could be caused if I was not able to get all of the coolant out and there's a little bit around the ignition coil/spark plug connection.
Have a feeling they may be related ha
