Sponsored by: Auxito
missfire on number one plug
Old Feb 26, 2013 | 03:23 PM
Richard.Parker's Avatar
Richard.Parker
I have a miss on cylinder one and i can not get rid of it. I have changed the plugs and i have changed the coil pack. I is a 2000 ford f 150 with the 5.4
The only thing i have not done is change the fuel injector on it. But I think maybe my problem is bigger than that. Does the cooling system run near it or by it because when i take the coil pack out it is soaking wet with water. that is the only one that is like that. when i take a flashlight and look down the hole where the plug goes i can see what looks like a spot where rust is and it runs down the side of the hole. Does anyone have any idea of maybe the head gasket or something is there that maybe i have blown and it is letting water in on the spark plug. Or if there is any other solution to the problem.
Old Feb 26, 2013 | 06:08 PM
vaper's Avatar
vaper
I am assuming this is coolant and not water?
Check for a leak at the cross over coolant pipe.It is a few inches in front
of that cylinder.
If you have to, pressure test the coolant system to find the leak.
Old Feb 26, 2013 | 06:31 PM
Richard.Parker
i assume it's coolant also though it's not green. it is a rusty color and doesnt smell like coolant but i havent put antefreeze in it since i ownded the truck for seven years. it has always stayed full. it sits on top of the plug and i assume it seeps down around the plug or fouling out the coil.
Old Feb 26, 2013 | 06:44 PM
Richard.Parker
Also I am just one person and I am not sure how to do a pressure test on one or what to look for. My mechanic passed away the other day and now im just kinda stuck not knowing what to do
Old Feb 26, 2013 | 09:01 PM
vaper's Avatar
vaper
You would need a pressure tester to do the test.Most shops would have this tool,it doesn't take long to do.
If you are sure it is water,being #1 cylinder only, I don't know where it could be coming from.
You need to find out for sure if this is water or coolant.
If it is coolant my first guess on this is a leak at the cross over.
good luck and keep us posted
Old Mar 18, 2013 | 08:42 PM
Richard.Parker
after spending plenty of money on new plugs and new coil and a new fuel injector, come to find out I'm pretty sure that I have blown the intake gasket.
bradleyheathhays
Nov 17, 2018 03:23 PM
DrMario
Aug 4, 2017 10:30 AM
jjclkc
13
Jul 5, 2016 03:34 PM
dillenger1
Dec 12, 2010 05:51 AM
KenJr
Modular V10 (6.8l)
Nov 30, 2007 09:51 AM
