now that's a heavy load!
Old Aug 1, 2017 | 07:53 AM
shizzu's Avatar
shizzu
Let's see if this link/video works....
https://video-atl3-1.xx.fbcdn.net/v/...15&oe=5980B23F
Old Aug 1, 2017 | 08:26 AM
HRTKD's Avatar
HRTKD
That's quite a load. I didn't run it with the sound on since I'm at work so if there was audio I didn't get that.
Old Aug 1, 2017 | 09:43 AM
jaherbst's Avatar
jaherbst
Good way to ruin a transmission. Talk about overheat!
Jack
Old Aug 1, 2017 | 10:09 AM
troverman's Avatar
troverman
I must have missed the context...exactly WHY was this pickup pulling this 18-wheeler? How do they get 176k lbs of weight? Why would you even do this unless it was an emergency? I imagine this is completely illegal. The hitch, let alone that chain, is not rated to move what was being moved.
Old Aug 1, 2017 | 10:23 AM
EpicCowlick's Avatar
EpicCowlick
The driver posted some of the details in the video description. He said the clutch on the tractor shattered and his trans and engine temps stayed normal. His reason for doing it was just to get the load off the road as he felt it was more dangerous to stay there and wait for a tow. Pretty unbelievable load and he had oversize Toyo MT's on the SD to boot. I'd say well done for the circumstances.
Old Aug 1, 2017 | 10:46 AM
Robeleo's Avatar
Robeleo
I saw it in the Facebook page and he posted this
Today the clutch blew to pieces while escorting my semi in KY. We are grossed out at 176,000lbs. To get it to a safe location - I decided to put the "Built Ford Tough" to the test. 4-Lo - diffs locked - starting on a hill. I have to say - I was BLOWN AWAY by how this truck pulled that! Never in a million years would I ever dream of hooking this to that kind of weight, but I had no choice. Didn't want to cause an accident. Pulled it 5 miles up and down hills. 10-12 MPH. NEVER exceeded 221 degrees on trans and 218 degrees on engine temp. I'm extremely impressed. Never will own a different truck. Some will disagree - as I did when I first thought about it. But getting off the road was the most important. #pleasedfordowner.
Old Aug 1, 2017 | 10:48 AM
Tedster9's Avatar
Tedster9
Well the piston rings are fully seated now I bet
Old Aug 1, 2017 | 10:51 AM
mack1080's Avatar
mack1080
I know I would have eventually created an account to ask for advice but had to do it now to say thank you for the great videos!! Please keep it up!
mack
Old Aug 1, 2017 | 11:06 AM
troverman's Avatar
troverman
Well, the wussy Tundra pulled the 292,000lb space shuttle, so I guess the Super Duty is a little more than 50% to that record...
Old Aug 1, 2017 | 11:37 AM
Adam R's Avatar
Adam R
Not a big deal at all. My neighbors very ancient D8 cat has 60 hp. Still manages to do an amazing amount of work, just not very fast. It's all in the gearing and I bet that truck was barely breaking a sweat.
Old Aug 1, 2017 | 12:40 PM
troverman's Avatar
troverman
You can bet that Super Duty was most definitely breaking a sweat. It is not geared to move that kind of weight, nor is the transfer case gears and chains designed to be subjected to that kind of weight. Using 4-low on dry pavement was probably the only way it could move this load, but subjected the drivetrain to that much more wear and tear.
Old Aug 1, 2017 | 01:21 PM
BLUENGRAY05FX4's Avatar
BLUENGRAY05FX4
Why is eveybody avoiding the OBVIOUS question...
Did he have his 1000 mile break-in completed before he did this?
Old Aug 1, 2017 | 01:26 PM
EpicCowlick
LOL. It would have been great to get the temperature of the rear differential. Might be a good idea to change that oil or test it in some way.
Old Aug 1, 2017 | 01:27 PM
Pwrgeek's Avatar
Pwrgeek
I'd be more concerned with slowing that monster down than getting it moving. With the clutch blown the semi doesn't have his jake so he's going to be relying on he friction brakes alone. Iffy depending on the grade on the other side of that hill they were climbing at the end.
Old Aug 1, 2017 | 02:47 PM
cficare's Avatar
cficare
Was years ago (1984?), and I don't know what it weighed, but I pulled a disabled 18-wheeler with my ol' '78 Toyota FJ40 Landcruiser. Only had to go about 3/4 mile on flat terrain.
