2001 Excursion door locks
Old Jul 31, 2017 | 07:39 AM
dada14's Avatar
dada14
Having problems with my 2001 excursion door locks. I have replaced the actuators before and everything worked fine. That was about 2.5 years ago. Now one day all of the door locks stopped working besides the drivers door. Rear hatch doesn't work either. They don't unlock or lock or even make a sound. Before when the actuators went bad it would make a noise. I've checked the switch in the door and check all the relays under the dash I'm lost on this one. I don't think it's the actuators bc the hatch has no action either. Any advice is appreciated
Old Jul 31, 2017 | 08:03 AM
dada14's Avatar
dada14
key fob works for drivers door. Also keypad will unlock and lock driver door but nothing else.
Old Jul 31, 2017 | 09:35 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Have any maintenance/repairs been done to the truck where stuff was taken apart and put back together in any panels or under the dash?
The locks run through the GEM module, but when this happened to me, it was the master switch in the driver's door. There is also the "lock out" switch for the rest of the doors there as well. Check the wiring inside the "boot" that channels the wiring from the driver's door back to the frame. After 17 years of opening and closing, a wire might have finally rubbed through and shorted out.
Old Jul 31, 2017 | 10:19 AM
dada14's Avatar
dada14
Appreciate it I'll check that out. I switched all the relays even though I could feel them clicking got nothing. I'll check the wires in the boot
Old Jul 31, 2017 | 10:44 PM
ford_model'a''s Avatar
ford_model'a'
I am not sure this will help, but on my 2000 Limited 7.3 it was programed to unlock just the drivers door with a single push of the fob unlock button. When you want to unlock all the doors and the hatch you do a quick double tap on the fob's unlock button.
Old Jul 31, 2017 | 11:16 PM
X Mahout's Avatar
X Mahout
Just went through this this weekend. Rear hatch would work at all. Wouldn't even lock with the key. Took the entire mechanism out. Sprayed it with engine decreaser, cleaned it, and applied a light grease to it. Lock works like a champ now.
Ryno1
Aug 19, 2021 12:25 PM
Bad News
May 7, 2018 07:25 AM
Hasbro61
Aug 25, 2016 08:46 AM
cc_rider
May 23, 2013 08:32 PM
hughie
Bronco II
Jun 24, 2003 02:20 AM
