No start
Old Aug 2, 2017 | 05:09 PM
Bearhugger1933's Avatar
Bearhugger1933
Where is the best place to get a gauge to check hpop pressure and is anyone in the spring tx area that knows anything about these beast,could sure use some help.
Thanks
Old Aug 2, 2017 | 05:44 PM
Bearhugger1933
Found gauges at northern tool,what pressure gauge and what size connection do I need.
Old Aug 3, 2017 | 06:42 AM
oldbird1965's Avatar
oldbird1965
Use a liquid filled gauge that will read 4 or 5K psi.
Old Aug 3, 2017 | 08:21 AM
Jarrett Campbell's Avatar
Jarrett Campbell
I think the HPOP lines are 1/8 or 1/4 NPT. There should be a kit with lots of different connectors though
Old Aug 3, 2017 | 08:51 AM
Bearhugger1933
Thanks I will get one at northern tool.
Old Aug 3, 2017 | 09:00 AM
Jarrett Campbell
Hopefully someone that actually knows the fitting size will chime in... I am going off vague memory
Old Aug 3, 2017 | 11:25 AM
Bearhugger1933
Can't believe that this thing stopped working sitting in the drive way,loading it up in a little while,taking it to my mech,at least I wasn't on the road.
Thanks Jim
Old Aug 3, 2017 | 06:52 PM
madpogue's Avatar
madpogue
BEST way to read injection pressure is via a device on the data link connector under the dash.
Old Aug 5, 2017 | 08:05 PM
Bearhugger1933
So got me a reader ,going to try to check pressure tomorrow,another question,what is the lowest voltage this thing will fire on and what does this voltage actually do.
Thanks
Old Aug 5, 2017 | 08:11 PM
oldbird1965
The lowest PSI is 500 before it will fire.
Old Aug 14, 2017 | 06:07 PM
Bearhugger1933
Update for those who helped,took truck to mechanic,still wouldn't start,let it set over night again,he tried to start it the next morning and it fired right up,he drove it for about 50 miles got home and tried to start it again no start,started checking again,found that the ipr had a problem,pulled it out and it came out in two pieces ,had to get the other piece out with needle nose,replaced with one from ford never heard this before,I told him to drive it for a couple of days to make sure everything was ok.
Thanks jim
DougH000
15
Aug 23, 2013 10:17 AM
Fla.Cracker96
13
Jul 28, 2013 06:55 PM
JamesHajek
Dec 20, 2009 11:39 AM
griff64
Jan 21, 2008 08:23 PM
02GrayPowerStroke
41
Jan 14, 2008 07:28 PM
