No start
Old Jul 30, 2017 | 07:25 PM
Bearhugger1933's Avatar
Bearhugger1933
No start
Ok guys I need help,truck ran good parked it last night,tried to start it this morning ,would not fire at all.sounds like bad cps but I get about 200 rpm when cranking,oil is full,WTS light comes on,fuse no 22 is ok,hpop was about11/4
Inch low,figured this was due to cranking,filled back up,will get a new cps from ford tomorrow. 95 f350 380000 miles.
Thanks jim
Old Jul 30, 2017 | 07:51 PM
z31freakify's Avatar
z31freakify
How cold is it in your area? GP could have taken a dump.
Old Jul 30, 2017 | 08:08 PM
Bearhugger1933
In the high 90',I also forgot to say that I get about 35 lb fuel while cranking.
Old Jul 31, 2017 | 07:38 AM
knottyrope's Avatar
knottyrope
how is oil level?
35 is good while cranking
do you get any smoke when cranking?
Old Jul 31, 2017 | 07:57 AM
Bearhugger1933
Oil level is full,even added another qt to make sure,didn't notice any smoke,going to get another cps from dealer in a few minutes.
Old Jul 31, 2017 | 10:54 AM
Bearhugger1933
Put new cps from dealer still want start ,also no smoke from tail pipe when cranking.
Old Jul 31, 2017 | 11:20 AM
Jarrett Campbell's Avatar
Jarrett Campbell
https://drive.google.com/file/d/0Byb...1qRU1VVGc/view
There ya go
Old Jul 31, 2017 | 11:42 AM
Bearhugger1933
Too small for me to read
Old Jul 31, 2017 | 11:45 AM
Jarrett Campbell
If you're at a computer, when you open it up, click the little + button on the bottom of the screen to zoom in. Or you can print it off.
If you're on a phone, just zoom in like any other picture.
Old Jul 31, 2017 | 04:28 PM
Bearhugger1933
Will have my daughter print it out when she gets home
Old Jul 31, 2017 | 08:56 PM
Bearhugger1933
Well I got my print out of the flow chart,will work on it for a little while longer,then will take it to my mechanic.
Old Aug 1, 2017 | 04:41 PM
Bearhugger1933
How do you check the Lpop and will it go out all at once.
Jim
Old Aug 1, 2017 | 05:34 PM
madpogue's Avatar
madpogue
Does the dash oil pressure "gauge" move after cranking for a bit? If so, the lube oil pump is producing "enough" pressure. You can also check the HP reservoir after cranking a while; should remain within 1" or so of the top.
Old Aug 1, 2017 | 09:06 PM
Bearhugger1933
Thanks I didn't think about that,I did look at the rpm but not the oil gauge,I filled the hp reservoir and it dropped about 1"after cranking will check the oil pressure gauge tomorrow,thanks again.
Jim
Old Aug 2, 2017 | 11:18 AM
Bearhugger1933
Ok ,check oil press gauge in dash while cranking,gauge jumped up to 50 percent so guess Lpop is ok,still no start.
