saving original bulb sockets laparoscopic surgery
Old Jul 30, 2017 | 03:08 PM
LIL LU's Avatar
LIL LU
If you have arcing in the sockets with good bulbs but they are still not working, Drill a small hole where you can see arcing in the plastic socket
Use rosin Core Solder and solder the loose/corroded joints through the hole.
make sure : connection is tight, pull on wires, bulb works when moving or pulling on wires
Use RTV or a waterproof sealer on the solder hole.
No more problems and no cut wires,this seems to be a common issue with this style socket .
Old Jul 30, 2017 | 05:33 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
One piece molded plastic tail lamps, tail lamp & backup lamps sockets are the same:
1974 F100/350 Stylesides from serial number T80,001; 1975/79 F100/350 Stylesides; 1975/91 Econoline; 1978/79 Bronco.
These tail lamp sockets are also the same as the parking lamp sockets for 1974 F100/350's from serial number T80,001; 1975/91 Econoline; 1978/79 Bronco, and...
1971/73 & 1976 Pinto; 1973 Torino & Mustang; 1975/78 LTD
Old Jul 30, 2017 | 06:30 PM
LIL LU's Avatar
LIL LU
Thanks Number... I had a turn signal socket doing the same thing. I replaced it instead of using this method. I could of kicked myself for not thinking of it earlier now I have spliced joints in the turn signal wiring although it is soldered and heat shrank. But still, these can be saved with no cutting unless rotted beyond help.
Old Jul 31, 2017 | 09:28 AM
HoustonDave's Avatar
HoustonDave
You may find yourself doing his more and more, the original single-filament bulb sockets for back-up lights are already out of production. If one of them goes bad you will HAVE to do this.
Glens67
24
Oct 27, 2023 04:43 PM
72rtchallenger
Aug 11, 2019 08:45 AM
Ibuildmyown
Aug 27, 2016 10:21 AM
Beachums
2015 + Expedition & Navigator
Oct 13, 2015 06:01 PM
camodown
Jul 24, 2008 12:38 PM
