79 f100 short bed build
#46
Yeah there are a lot of these trucks in KY , sorry to hear about the poor sale you got ,
I started reading over your thread, seen all y’all talking about around where I live. So cool to see people so close. I’m in Mercer county and got mine from nicholasville, it was a piece of junk though but thought the mechanical were good because I was buying off a guy who owned an auto shop. Turns out he’s a lying crook and after I made it a few miles down the road what seemed great started falling apart quickly so now it’s a complete redo. But anyways, I like seeing what your doing, it looks awesome!
#53
Yeah unfortunately I have to paint outside , of course you will deal with some dust , especially if you live on a farm as I do , Try an pick the least windy day an over concrete area if possible and if so water the concrete down to keep dust down , which I wish I could do but cannot, I have painted a few outside and buff out most dust an pest (insects )after it dries but not all..I do an try to paint fenders an doors inside an any smaller parts when I can an that helps but the cab an bed I will be doing outside ,,the dust gets in the clear coat more than the base coat so some wet sanding and buffing go a long way
#54
Now I do have a small indoor shop where I can paint small parts like you say. BUT, I can't my truck inside.....
Are you planning to use lacquer paint?
#55
We are in the same boat. I have to do the best I can. Heck, we can't all have a 2500 sq ft air conditioned shop to paint in!
Base Coat/Clear Coat Kit
Type:Urethane Base Coat
#56
#57
door rust
fixing lower rust on doors but its progress , got lower skins cut off and some cleaning an inside pans not bad but one door has little more rust through but fixable and new skins are crimped so they can slide under and make a neat job,,still need to put some por-15 and primer before installing an welding
#59
door work
Fixed the one corner that was rusted and cleaned up and test fitted panels on the doors , so far so good and did some cleaning on bottom of hood,,bottom of hood had surface rust all over bottom as previous owner left it out but its not rusted through . just a pita to clean without sand blaster ,,but wire brush on drill is working just slow
