Phosphorus
Old Jul 27, 2017 | 02:53 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Phosphorus
Phosphorus is used in the new Motorcraft oil to reduce wear. You don't see that on other oil containers.
Old Jul 27, 2017 | 03:01 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Does it get glowing reviews?
Old Jul 27, 2017 | 05:25 PM
Whitey Ford
I was hoping someone could enlighten us with a shining recommendation. I see Ford is using 1.25 gallon containers so you only need 3, at a cost of $18.53 per.
Old Jul 27, 2017 | 10:45 PM
Colorado350's Avatar
Colorado350
That just wrong!
Old Jul 28, 2017 | 11:47 AM
SteveH-CO's Avatar
SteveH-CO
Here's a review - glowing or not...
Ford Motorcraft Super Duty Formula SAE 10W-30
Old Jul 29, 2017 | 08:44 AM
dn29626's Avatar
dn29626
I guess I am a tester, since I have always used Motorcraft motor oil, and plan to continue.
I hope Ford's endorsement of Motorcraft continues.
Old Jul 29, 2017 | 08:07 PM
carltonwebb's Avatar
carltonwebb
It doesn't show on the front but i think it has a different rating than Cj4.
I remember seeing but not only skimming a TSB that came out at work that addressed that oil. If I remember right, the new diesels required that different rating whereas all the older fords, cummins, cats, and detroits did not. I did not read it because i do not have any new ford diesels that i maintain but can read it next week.
I could see that knocking an oil sample off if you perform those regularly.
Old Jul 30, 2017 | 07:30 AM
Whitey Ford
Thank you. If all the new CK-4's have to meet Ford's F1 rating, it would seem it is the top of the lube chain. I am going with it next week if everything checks out. I have only used DELO 400, but they have not made the list YET.
Here is the list that of oils that currently meet Ford's WSS-M2C171-F1 that F-350 posted:
http://www.lubritecinc.com/PDF/diese...=%5B%5Beui0%5D
Thanks again!
Old Jul 30, 2017 | 07:48 PM
F350-6's Avatar
F350-6
That's actually the older list. Here's the new one. It contains some additions to it (including motorcraft)
File Type: pdf
Old Jul 31, 2017 | 07:09 AM
Whitey Ford
Thank you. I was hoping to see DELO 400 on there, but glad to see Motorcraft meets it's own specs and made the list.
Old Aug 8, 2017 | 02:57 PM
Whitey Ford
Going with the Valvoline Heavy Duty, just $11.53 a gallon from Walmart. Thanks again!
Old Aug 8, 2017 | 05:54 PM
Whitey Ford
It is still the CJ-4 recipe.
Old Aug 9, 2017 | 05:13 AM
dn29626's Avatar
dn29626
I wonder if that is NOS oil.
Old Aug 9, 2017 | 04:52 PM
Whitey Ford
Maybe not that old of a recipe.
Old Aug 13, 2017 | 04:58 PM
ExPACamper's Avatar
ExPACamper
You guys are killing me...thought I knew which oil to use
Is Valvoline CJ4 good to use? Wonder if they have it in 5w-40w for winter?
