Phosphorus
Old Aug 17, 2017 | 12:17 AM
retiredsparky's Avatar
retiredsparky
It is my understanding that CJ-4 is ok, but not CK-4
Old Aug 17, 2017 | 11:18 AM
ExPACamper's Avatar
ExPACamper
What if it has BOTH on it?
Old Aug 17, 2017 | 11:41 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
If only CJ-4 appears under API service and CK-4 is NOT present, it is ok to use. If CK-4 appears on the API service, that oil needs to be on the latest Ford approval list, that F-350 posted earlier, before that brand can be used safely.
Old Aug 17, 2017 | 06:09 PM
F350-6's Avatar
F350-6
The claim is that CK is backwards compatible, so the argument can be made that any CK oil is safe for CJ rated engines. Not so according to Ford. Smart advice is to ignore the label and choose an oil on Ford's approved list.
Old Aug 17, 2017 | 06:27 PM
ExPACamper's Avatar
ExPACamper
Yeah, it looks like Ford and the EPA changes to the oil have really made a mess of things
Thanks all for the info
When my new (rebuilt) injectors arrive, what would YOU run?
Old Aug 17, 2017 | 06:43 PM
F350-6's Avatar
F350-6
Ask me next week. I've sent off a sample of the Valvoline heavy duty to blackstone and am currently awaiting results. I may or may not change my opinion once I receive the results.
Old Aug 17, 2017 | 06:54 PM
ExPACamper's Avatar
ExPACamper
That would be excellent timing, thanks!
Old Aug 27, 2017 | 02:08 PM
trekbasso's Avatar
trekbasso
So, what changed with the older oils? I have been using either Rotella T or Mobil Delvac 5-40 for years with great Blackstone reports. I have seen a lot of mention of but haven't seen why the CK designation is bad?
Thanks.
Old Aug 27, 2017 | 07:28 PM
F350-6's Avatar
F350-6
Thanks.
Because to meet the new CK rating, they had to pull more good stuff out of the oil so it doesn't lubricate as well as it used to, but it does help with emissions.
Walking helps with emissions too, which is what Ford is hinting we might be doing if we start using a non-approved CK oil.
Old Aug 28, 2017 | 05:58 AM
Whitey Ford
Can't wait to hear your results!
Old Aug 28, 2017 | 09:38 AM
ArmyLifer's Avatar
ArmyLifer
So, should I be worried that my last oil change with Shell Rotella T6 isn't on the approved list? What should I change to? Should I shorten my change interval and get it out of there?
Old Aug 28, 2017 | 09:39 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Nope, you should not be worried at all about T6.
Old Aug 28, 2017 | 10:18 AM
  #28
trekbasso's Avatar
trekbasso
Thanks Chris. Crap this is confusing. Most of the recommended oils are 15-40, not much out there in the 5-40 range. Plus this seems to start with the 6.7s? Talk about tighter clearances, etc. Might just stay status quo, shorten my change interval and ship off to Blackstone sooner rather than later. At least until my injectors die, then "honey, I have to replace them"!!
Old Aug 28, 2017 | 11:13 AM
  #29
Whitey Ford
I used Delo for 16 years and refuse to use it till it makes the list. Went with Valvoline HD this time under F-350's recommendation. If he has 600k on a 7.3 his word is gold.
Old Aug 28, 2017 | 07:59 PM
  #30
F350-6's Avatar
F350-6
Me too. Not a peep from Blackstone yet, but they haven't charged my card yet either, so maybe they're just behind. Or the sample got lost in the mail.
