Ford Flathead 226 H 1951 Motor Head Gasket, HELP!
Hi Everyone,
Been sometime since I last posted but visit often.
I am in need of some advise and guidance. Just recently my flathead 6 started smoking. Its never done this in the past. The smoke is white, smells like winter green and quickly evaporates. The motor was rebuilt about 1000 miles ago (1 year ago) and has ran very strong with no problems.
Now I am no mechanic but have an idea what possibly caused this problem. After picking up the motor the engine builder told me to torque the head after the first heat cycle and then after the first 300 miles.
Well I forgot all about it and did not torque it till after I saw trails of coolent from the back of the head. Not sure how long it had been leaking but I am thinking it must have been for at least 3 months (drive the truck only on the weekends). I noticed the trails one night while inspecting the motor at night with a flash light. I have torqued the head 2 times 60 and 65 pounds.
The leaks did seal and the truck did not smoke. I am assuming that some of the sticky stuff used on the copper head gasket must have washed away and the gasket has been compromised.
What gasket should I be using (Copper? Do they come in other materials?)
I think it will be a straight forward job (according to the manual) or should I be looking at farming it out? I do have tools and can probably break it down my self.
Should I have the head resurfaced or can I just replaced the gasket?
Thanks for your guys help!
I haven't used thread sealant. The copper coat seams to squish out enough when the head is torqued to seal the head bolts; I haven't had seeping head bolt issues on a Flathead Ford.
I should have been more clear, torque the head bolts in three stages like 25, 45, then 65 lbs. Follow the torque sequence each time; yes it gets tedious. When you re-torque do two stages, 45 then 65. I re-torque after each heat cycle until the readings stabilize, typically three or four times.
I haven't done a head gasket on a flathead six in about twenty years (I was in high school). The two I did I just followed the shop manual, no problems. Today I would back down to 55 ft-lbs. With the large number of fasteners and lower compression of the vintage engine I don't see a need to go to the high side of the spec.
