Brake question
Old Sep 6, 2003 | 06:30 PM
tinner7's Avatar
tinner7
Question Brake question
Hi, I just got done putting new pads and shoes all the way around on my 89 ranger, I even put in new rear master cyclinders and front calipers. I bleed the brakes, but when I start the truck up, the pedal still seems spongie to me, like I still have too much travel in it before the brakes catch. Is there something I am missing? any help would be great. it may be that I am just so used to the brakes on my 03 and forgot how the older trucks where!
Old Sep 6, 2003 | 06:47 PM
stepman's Avatar
stepman
Brake question
When you pump the pedal does it get hirer? If so, you probably have air in it. If not, don't worry about it, unless when you push the pedal it goes all the way to the floor. The brakes should seat and the pedal will sink a little less each time. When you put new pads on, the rotor is not perfectly flat like the new pads are and need time to adjust. A good 5 mi stop and go drive should seat the pads. This should be done somewhere that you can get up to at least 40-45 mph with stops and slowing in between. The idea is to "grind" a little material off of the pads without getting them too hot.
wade67
25
Oct 30, 2013 06:53 PM
Diesel_Brad
May 8, 2012 04:29 AM
jleo
Apr 4, 2010 01:29 PM
csangster
Sep 1, 2008 10:27 AM
ol74hb
Sep 12, 2004 07:56 PM
