Muffler knowledge needed
Old Jul 26, 2017 | 01:14 PM
Ozzie H.'s Avatar
Ozzie H.
The vehicle: 1976 F-250; 460; C6; aft axle and (driver side) mid-ship fuel tanks; stock exhaust.
Stock exhaust consists of stock cast iron exhaust manifolds discharging into 2-1/2" exhaust pipes. Both exhaust pipes discharge into a single muffler on the passenger side of the truck. The exhaust pipes & muffler combination was serviced under part number D5TZ 5230-BM. The muffler discharges into a single 2-1/2" tailpipe which exits on the right side of the truck behind the rear wheel.
The exhaust pipes and muffler are in excellent condition. The tailpipe was somewhat "patched up" due to the effects of corrosion.
As the truck is driven very conservatively only on the street, I would like to replace the tailpipe with either two 2-1/2" or one larger (3" or 3-1/2") custom bent stainless tail pipe(s).
The problem is that I don't know the internal structure of the stock muffler, and if such a proposal is feasible.
I'd appreciate any advice regarding the internal structure of this muffler. I suppose that I could cut off the muffler's rear cap and restructure the internals, but I'm trying to make the job as simple as possible.
Thanks for any advice.
Old Jul 26, 2017 | 01:19 PM
Dave145's Avatar
Dave145
Best bet there would be to get a "dual in dual out" muffler. There's no one way I'm aware of to restructure your existing muffler to go from one to two tailpipes. Granted, you could always add a Y pipe after the muffler to give you two tailpipes, but that doesn't really accomplish much but drain the wallet.
Single 3" out is doable with an adapter from your local Mc.PartsStore. However again you're really not gaining much. Why not just replace the stock 2.5" tailpipe?
Old Jul 26, 2017 | 02:19 PM
HIO Silver's Avatar
HIO Silver
A dual 2.5 inch inlet, single 3-inch outlet muffler is perfectly acceptable for your configuration. Choose one of a reputable brand.. Magnaflow, Borla, Flowmaster, etc.
Old Jul 26, 2017 | 07:15 PM
Blue and White's Avatar
Blue and White
Do the current pipes (2 1/2"?) from each cylinder bank merge before the muffler or at the muffler?
Merge before the muffler in a "Y pipe" would be a common stock setup. Merge at the muffler would probably be retrofit.
Old Jul 27, 2017 | 05:31 AM
Ozzie H.'s Avatar
Ozzie H.
I could, but I was hoping at the same time to get a bit better "breathing" for the 460 by increasing the outlet size on the muffler.
Old Jul 27, 2017 | 05:38 AM
Ozzie H.'s Avatar
Ozzie H.
That has been one of my considerations, and I have been looking at what the industry has to offer, but since the existing muffler and exhaust pipes are in such good condition and "fit" so well, I thought that I'd first explore the possibility of modifying the outlet cap of the muffler to accept either a larger pipe or two 2-1/2" tail pipes.
Old Jul 27, 2017 | 06:15 AM
Ozzie H.'s Avatar
Ozzie H.
Rear (outlet) cap on muffler connecting to single 2-1/2" tail pipe
Two 2-1/2" exhaust pipes from engine connecting to front cap of muffler
Muffler on truck showing driver side mid-ship fuel tank in foreground and driveshaft between them. Stain on muffler is lube spray from recently greased U-joint.
This arrangement is original, as confirmed by drawing in the Ford truck parts book. Please excuse the green tint. My work light was fluorescent.
Old Jul 27, 2017 | 10:46 AM
84espy's Avatar
84espy
I was fortunate enough to get a Flowmaster dual 2.5" in/out for my 460. Had the exhaust routed out behind rear tire. Love it Engine breathes easy and sounds great. Concerning one of your comments earlier, your engine will only breathe as easy as the smallest restriction.
Old Jul 27, 2017 | 02:42 PM
HIO Silver's Avatar
HIO Silver
I had some take-off 2.25-inch in and out Flowmaster 40s but needed 2.5 inches in and out. Come to find out they were the same internally so it was just a matter of cutting off the 2.25s and welding on 2.5-inch ins and outs.
Old Jul 30, 2017 | 05:44 AM
Ozzie H.'s Avatar
Ozzie H.
Thanks!
Thanks to all for comments and ideas. I'll be doing a bit more research before deciding on the path to follow.
Old Jun 17, 2024 | 01:34 PM
ribbons8489's Avatar
ribbons8489
Flowmaster
I am working on getting the new Flowmaster dual in single out on my truck right now. Glad to here it works well for you, I wondered when I bought it but had to replace the entire exhaust on my 76 Ford f250 it has been a royal pain in the butt. I will never order from Walker Exhaust again - the exhaust I received was so far off it would not even attempt to fit on the manifolds and would exit at the rear tire so have had to build it all myself.
Joe Barker
Apr 30, 2019 09:23 AM
two4two
Oct 29, 2012 12:11 AM
ackeiyword
2004 - 2008 F150
Jan 8, 2011 10:26 PM
Ford_Six
Exhaust Systems
Aug 28, 2007 04:47 PM
1tonJudd
Modular V10 (6.8l)
Jul 5, 2004 06:31 PM
