Starting issues/ solenoid
Old Jul 25, 2017 | 12:11 PM
87diesel6.9's Avatar
87diesel6.9
Exclamation Starting issues/ solenoid
My 1987 ford with the 6.9 is having starting problems. The wait to start light would not light up, and little smoke was coming from the solenoid, i would go to start and i would get nothing. I bought a new solenoid and put it on and the wait to start light lit up for one cycle of the glow plugs and when it went off i turned the key to start it and all i got was a clicking sound. I tried to cycle the plugs again, but got nothing when i turned the key.
Old Jul 26, 2017 | 05:08 AM
hturner12's Avatar
hturner12
Sounds like a bad starter. Starting and glow plugs are 2 separate systems that work together during the start cycle. The glow plugs are an aid to starting. Did you bypass the starter solenoid? I use the screwdrive between the 2 big post. The starter solenoid is mounted to the fender close to the battery. It serves also as junction box for other things. It will have a wire coming direct from the battery.
Old Jul 26, 2017 | 10:38 AM
87diesel6.9
I went out to try to start the truck today. The dome light came on, but i had no radio or anything light up. i turned the key tried to start it and got nothing. dome light isn't even on now. batteries are both fully charged and they are only a couple months old interstates 1000 cca. what would be causing all of that?
Old Jul 26, 2017 | 10:44 AM
hturner12's Avatar
hturner12
Bad ignition switch, bad ground, bad starter ,bad starter solenoid, blown fuseable link
Old Jul 26, 2017 | 11:07 AM
87diesel6.9
Where are these blown fuseable links located, and where do they go to and from?
looker44
Dec 2, 2014 12:20 PM
Ericfrickey
35
Mar 16, 2013 10:01 PM
beersy50
Feb 7, 2013 07:41 PM
bburrito
Sep 18, 2011 01:13 AM
Skier041
17
Feb 29, 2008 10:52 PM
