no start
Old Nov 30, 2014 | 12:27 AM
looker44's Avatar
looker44
no start
Okay to start off I'm new to diesel and I figured start of simple so I got a 87 6.9 with 91000 all original miles well all was going good for about3 weeks and it started acting like the starter would stick and try to turn over by itself so I did some research and found a bad solenoid and ignition switch so I replaced them both and then it wouldn't turn over at all so I tried to jump it and found I had a bad starter so I replaced that and now with the truck on jumper cables for over an hour it will not engage the starter I have power to everything but the starter will not turn any ideas? According to the volt meter I have 8 with the glow plugs and when they shut off it goes to about 10
Old Nov 30, 2014 | 09:42 AM
Fireman_dave's Avatar
Fireman_dave
Sounds like a battey issue to me, should have around 12.5 to 12.75 and about 11 glow plugs lit, if one battery has a dead cell it will drain the other, charge them both individually then test each individually
Old Nov 30, 2014 | 09:53 AM
looker44's Avatar
looker44
alright I'll give it a shot here in a few
Old Dec 1, 2014 | 10:24 PM
looker44's Avatar
looker44
two brand new batteries and still the same thing starter tests good still just spinning any help would be greatly appreciated I'm borrowing a truck I don't want to be stuck in a Chevy forever
Old Dec 1, 2014 | 10:31 PM
Fireman_dave
Where are you checking voltages at
Old Dec 1, 2014 | 10:32 PM
looker44's Avatar
looker44
At the gauge the simple test light will light up on the starter wires
Old Dec 2, 2014 | 12:20 PM
Fireman_dave
Ok....i was assuming that you were checking it at the batteries. Check your grounding from batt to engine engine to chassis, very common
Clyde Percy
Feb 10, 2017 07:49 PM
Firefighter 1406
56
Jan 5, 2017 07:21 PM
meierw1
15
Dec 12, 2012 10:28 PM
DWhiteyF250
15
Jul 25, 2012 11:59 PM
MustangMatt96GT
Mar 29, 2009 05:06 PM
