6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Ford Shuns New API CK4
Old Jul 24, 2017 | 07:30 PM
Picton's Avatar
Picton
So I saw this in the 6.7 section just now. I wish I had seen it before last weekend. I just put 15 quarts of the Chevron Delo CK-4 in along with a bottle of Archoil friction modifier. Similarly to diesel engine coolants...I figured if Caterpillar approves...why the hell wouldn't Ford(Navistar/International in our case)? Do I need to change the f&46ing oil again? I would assume to do the filter as well. Roughly $80 if I don't spring for more Archoil which I feel the need to. Damn. Thoughts?
Old Jul 24, 2017 | 07:34 PM
Firefighter 1406's Avatar
Firefighter 1406
I had seen this also. I thought I remember reading Ford was recommending a different type of oil then the type you have pictured. Let me see if I can dig it up.
Old Jul 24, 2017 | 07:53 PM
Picton's Avatar
Picton
Yeah...It's the in-house Ford WSS-M2C171-F1 spec. Either that or the old CJ-4. I mean...5k miles couldn't hurt the thing. Right?
Old Jul 24, 2017 | 07:59 PM
Firefighter 1406
I wouldn't think so if it's a one time thing. Either that or just go 3,000 on this change and get I think out of there.
Old Jul 24, 2017 | 08:54 PM
Picton's Avatar
Picton
Yeah...I think you may be right. It is strange though because technically this new spec outperforms the others all around. Ford ended up having some "abrasive wear" concerns after in-house testing and decided not to recommend it for any of their PSD engines.
Old Jul 24, 2017 | 10:48 PM
Firefighter 1406
I know it was a big concern in the 7.3 forum. There was guys stocking up on the older style oil.
Trying to figure out what oil I am gonna run myself.
Old Jul 25, 2017 | 10:38 AM
brada's Avatar
brada
I have been wondering if Ford looks at the oil performance after re-gens adds diesel to the oil?
Old Jul 25, 2017 | 11:05 AM
Picton's Avatar
Picton
You bring up a good point. Ford is obviously considering how the oil performs with all emissions equipment intact.
I wonder if I'd be just fine running CK-4 with the deletes? Thoughts?
Old Nov 26, 2017 | 05:56 PM
Picton's Avatar
Picton
So I've thought more about this. I just went back in with the same Delo 400 CK-4. I don't buy that when nearly every other diesel mfg is okay with the CK-4...only Ford isn't. You can't find CJ-4 anymore in the store.
Ford is just ensuring they can deny a warranty claim unless you use their in-house spec.
I'll be using a good brand name CK-4 (same as oil pictured above) and changing every 5k as usual.
Old Nov 27, 2017 | 12:32 PM
speakerfritz's Avatar
speakerfritz
the report I saw refered to pre-mature wear....so that tells me not enough zinc and phosperous....so if you add archoil...that would be enough for me not to worry about it. prestone makes a zinc / phosperous additive that comes in a small yellow bottle that costs about 10 bucks.
Old Nov 27, 2017 | 12:57 PM
Firefighter 1406
I will have to check out the Prestone stuff. The older oil is getting harder and harder to find.
Old Nov 27, 2017 | 02:33 PM
speakerfritz
Old Nov 27, 2017 | 02:48 PM
Firefighter 1406
Thanks fritz, I appreciate it.
Old Nov 28, 2017 | 01:48 PM
Robert Green's Avatar
Robert Green
I was wondering about this just last week when buying oil.
Went with Rotella T4, which clearly shows it meets CJ-4 on the back of the bottle.
It does smell rather bad compared to the Valvoline High Mileage diesel oil I ran on the previous change. Threw in 16 ounces of Archoil last night as well.
One other thing I've noticed about the Rotella is that it seems to run a couple degrees hotter than the Valvoline as well.
Old Nov 29, 2017 | 06:04 PM
Picton's Avatar
Picton
I also run the Archoil friction modifier at every oil change(5k). All the name brand CK-4 oils (for me Chevron DELO 15W-40) note that they meet or exceed the CJ-4 and all previous specs of engine oil(ASME). It just seems odd that only Ford would have an issue and those like CAT, Mack, and Cummins (among others) approve of CK-4 performance.
MDF4J
6.2L V8
23
Jul 13, 2018 03:47 PM
krecak
Oct 1, 2017 10:01 AM
Kbota
6.7L Power Stroke Diesel
Sep 8, 2012 07:42 PM
NewDiesel-N-Town
Mar 9, 2009 09:37 PM
boulderbronco
Mar 5, 2008 04:54 PM
