1978 - 1996 Big Bronco
92 Bronco upgrade AC to R134a - Components and Assembly
Old 07-24-2017, 03:18 PM
75_92_95's Avatar
75_92_95
75_92_95 is offline
I am finally getting around to the R134a upgrade. I have removed the R12 AC from the Bronco and am about to try to build the R134a system from new components and install it.
I have never messed with AC before. I followed a removal description from another site to get the old system out. It was simple enough since I just replaced the heater box after shattering it when a tire chunked its tread.
1993 Ford Bronco A/C Conversion to R-134a picture | SuperMotors.net
I know that I need to fill some of the components with oil before assembling this but I'm not sure how all this goes together since I couldn't find a step by step assembly description anywhere. I can put it all together to look like the system I just removed but I need to make sure I get it all lubed correctly before I run it down to have a shop charge it up.
These are the components that I bought from ORy and have on hand for the new system:
Murray 7-4150 Condenser
Murray 56115 Hose Assembly
Murray 58120 Compressor
Murray 60-4518 Accumulator
Murray 54541 Evaporator Core
Murray 55712 Hose Assembly
Murray 38904 Orifice Tube
Murray 36676 Switch Interruptor
Tech Select 26777 Rapid Seal AC System (caps and seals)
Several of these items have o-rings included. I have no idea which of the o-rings to use in assembly. I am also concerned about whether to lube the o-rings and what to use as a lube.
I don't have any oil for the compressor, etc. yet so I wonder what type of oil, how much to use in assembly and which components to pre-lube. I think I need PAG 46 but I'm not sure how much to put in each thing and whether any are pre-lubed so that oil isn't needed.
I guess I am hoping to get a step-by-step assembly description so that I can get this together right the first time.
Thanks for reading this far.
Thanks.
Old 07-24-2017, 04:57 PM
Warwaggon92's Avatar
Warwaggon92
Warwaggon92 is offline
Hey man I don't need to get off of topic but do you have an E40D in the 92 Bronco? Is it 4 wheel drive? I need to know where your speed controller is. I'm putting a 92 engine and transmission in my 92 ranger and the speedometer is not working. I need to know if that's because the speed control is not hooked up because it was in the rear axle of the Bronco and I didn't take it with me or if it's in the transfer case and maybe I'm not sending power to something and that's why the speedometer is it working
Old 07-24-2017, 05:40 PM
75_92_95's Avatar
75_92_95
75_92_95 is offline
i believe it is a sensor in the electronics at the back corner above the pan on the passenger side of the transmission.
Old 07-24-2017, 05:42 PM
Warwaggon92
Thank you so much man I really appreciate it. Sorry to hog your post and get off topic
Old 07-24-2017, 09:31 PM
75_92_95's Avatar
75_92_95
75_92_95 is offline
No worries. I appreciate you reading far enough to figure that I might be able to answer part of your question. Not getting anyone else chiming in and I have most of it together now anyway so I'm hoping for the best tomorrow when I wrap it up and get it charged.
Old 07-27-2017, 12:09 AM
75_92_95's Avatar
75_92_95
75_92_95 is offline
I have moved this to the Cooling, Heating, Ventilation and AC forum.
Thanks for reading.
I don't know how to delete it from here but if you are interested in replying please go to that forum.
cohomology
07-08-2016 09:19 AM
Akzep69
06-20-2015 04:07 PM
10thMountainMechanic
36
03-08-2014 02:07 PM
billj6
1983 - 2012 Ranger & B-Series
07-23-2008 06:24 AM
JTHill24
Aerostar
06-30-2006 09:28 AM
Quick Reply: 92 Bronco upgrade AC to R134a - Components and Assembly
