92 ranger/92 bronco swap - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco
Old 07-24-2017, 04:23 PM
Warwaggon92 Warwaggon92 is offline
Warwaggon92 is starting off with a positive reputation.
Doing a 92 ranger v8 e4od swap with a 302 and an e4od. 4x4.
Build is 99%. I have no power to the Speedo. I can shift manually. So the Speedo is not getting power. Isn't working. Stuck on 0. Won't shift in drive.
Is the speed controller in the 92 ranger in the rear axle or is it in the transfer case?
If it goes in the rear axle does anyone know how or where to buy one? Can I put it in my 8.8?
Please help!!
Old 07-24-2017, 04:45 PM
Old 07-24-2017, 04:46 PM
Old 07-25-2017, 09:05 AM
exranger06 exranger06 is offline
exranger06 is starting off with a positive reputation.
92 Bronco should use the sensor in the rear axle for the speedo. 92 Rangers I believe use a cable-driven speedo that's driven off the transmission or transfer case. I know the 1st gen Explorers use a cable driven speedo, so the same year Rangers are most likely are the same.
Rangers came with rear ABS during those years (at least some of them did). There will already be a sensor on the axle if it has RABS. If it doesn't have RABS, you'd probably be best off swapping in an axle that does.
Old 07-25-2017, 08:06 PM
https://youtu.be/CpSI-KFc-Lwg
Will this work? Is this what I need?
Old 07-26-2017, 03:02 PM
Yes, that will work too. I'm assuming they have different models for different axle gear ratios. The sensor on the axle measured wheel RPM, which is unaffected by the gear ratio. By putting the sensor on the driveshaft, the sensor will be reading RPMs anywhere between 2.73 and 5.13 times the wheel RPM, depending on what gear ratio is in the axle.
Old 07-26-2017, 05:05 PM
Disregard. My mechanic is a f****** numb nuts. I have the same g** d*** sensor In my 8.8 rear. I just be to go to a junkyard and get the harness and install it properly. I know that the harness goes from the abs sensor to the transmission. Does it also go to the main wiring harness? Or the computer that runs the transmission? If so do you have any idea on where? I'm just wondering because I need to go to a junkyard and if I need to rip apart Dashboards that I need to go With all of my tools
Old 07-26-2017, 06:08 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
that signal would pass thru the 4wabs control module located under the washer fluid tank on a fullsize bronco.
if the tooth count on your current ranger 8.8 tone ring is different then you will need to calibrate your PSOM.
Old 07-26-2017, 06:10 PM
OK so it goes to the outside harness not the interior harness? In other words when I'm rubaye this thing out of AF 150 or Bronco I don't need to rip out the dashboard?
Old 07-26-2017, 06:15 PM
no you might still need to do that. dont quote me though.
Old 07-26-2017, 06:26 PM
Ok. Thanks a lot for the info !
Old 07-27-2017, 06:15 PM
Does anyone have any information on exactly what I have to hook up to make the E40D shift? Does the AVS sensor get hooked into the transmission? And that's all I need to make it shift? Or does it go into the transmission and then go into the main wiring harness
Old 07-27-2017, 06:55 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
On that vintage truck the speed input comes from the rear end to the PSOM in the dash cluster.. that is the middle plug, and from there is carries on to the PCM which in this case controls both the engine and transmission.
92 f250 4x4 e4od Transmission swap to manual OldschoolBoy Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 12-10-2016 03:04 PM
97 5.4L tranny swap with a 92 e4od? Cody Dusinberre Clutch, Transmission, Differential, Axle & Transfer Case 3 07-21-2016 07:55 AM
92 bronco E4OD into a 90 bronco Gen 1 driver 1978 - 1996 Big Bronco 1 10-24-2015 08:52 AM
Wheel Cylinder Keeps Blowing Out 92Ranger123 Ranger & B-Series 34 08-11-2013 10:21 AM
how to reset speedometer leeiwonfan3 1987 - 1996 F150 & Larger F-Series Trucks 14 06-21-2004 07:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
