2017 Bed Drain Holes?
Our work trucks came to us with the factory drop in bed liners. There are no drain holes in them. If we were to drill a few strategically placed holes in the plastic I'm wondering if there drain holes in the bed? Seems like there should be but I have never paid attention to other trucks.
I haven't pulled the liner yet but I looked underneath the truck and couldn't see any holes.
Thanks!
Thanks!
There are drain holes in the bed. The drop-in liners normally don't have them....I've never been able figure that out. Days after a rain, the drop-ins will still have gallons of water in them.
Lots of people drill holes in them...if they don't want the water in there. The only alternatives are heavy acceleration forward, strong braking when backing, or park with the nose uphill.....or bed covers.
I've never seen a drop in bedliner with factory made drain holes. That's for a reason. Why would you want whatever accumulation of dust, dirt and crap that collects in the bed to drain out of the bedliner and into the the space between the liner and truck bed? Let enough crap get in the bed and those factory holes can plug up.
So the bedliner gets some water in it. That hurts what? As noted, if water collecting in the bed is an issue...turn the truck around next time...but don't ruin the liner by cutting holes in it.
Heavy acceleration or strong braking?
I've found that with the water we have here in Alabama, simply letting the water run towards the tailgate allows it to drain right out.
My 2005 F350 PSD had a factory drop in bed liner with holes in it. That was the only way to reach the factory tie-down brackets welded to the front corners of the bed. You're right though - for days after it rained water dripped out the back end from between the liner and the bed.
I have always heard that a drop in bed liner is one of the worst things you can do to a truck. Between the dirt and moisture that gets between the bed liner and the bed, the vibrations of the liner wear the paint on the bed and then the bed rusts. Better to not use a liner or just use a rubber bed mat. I have a bed rug in the truck now and I like it a lot. Easy to remove and rinse and nice and comfy on the knees when you have to crawl in the bed.
I have a Line-X liner in my current truck. Seems like you could bounce artillery shells off it. Lifetime warranty if you screw it up. Not terribly knee friendly though. Unfortunately, I also use the factory bed divider and anything thicker than the Line-X will stop you from latching in the divider.
I can see where they would be useful to people that carry large heavy objects in the bed that might otherwise scratch or dent the bed. But for me, that's not an issue. But, like I said, they have their place and usefulness.
In my new truck, I have nothing. If it gets too scratched up, I'll get a spray-in liner.
We have the factory spray-in liner. We've had LineX in the past on previous trucks, and I do not see a huge difference (in spite of some people's criticisms). Our dealer originally recommended the LineX when we got ours, but the local LineX shop had a multi-week waiting list. So we went with the factory version. No problems whatsoever. This week we added the BedRug Mat. Kind of like having your cake and eating it too.
