SHIFT SOLENOID
Old Jul 24, 2017 | 09:54 AM
g tinsley's Avatar
g tinsley
SHIFT SOLENOID
Transmission was not shifting out of second gear set a code stuck solenoid cleared code seems to be working now any suggestions
Old Jul 24, 2017 | 09:59 AM
g tinsley's Avatar
g tinsley
shift solenoid
Transmission is in 05 6 liter diesel
Old Jul 24, 2017 | 06:31 PM
87crewdually's Avatar
87crewdually
You need to atleast post the code.
Here's a diagram of the solenoids.
Old Jul 25, 2017 | 07:22 AM
Apocalypse's Avatar
Apocalypse
I purchased new (stage 2) solenoids from FICMrepair.com a few weeks ago for like $125 each. If you need to replace them I would go with those
Old Jul 25, 2017 | 02:26 PM
g tinsley's Avatar
g tinsley
stuck solenoid
p0771 shift solenoid e stuck p2704 friction element e stuck this happened in tow haul cleared code works fine without tow haul thanks for your input
Old Nov 28, 2022 | 03:16 PM
Mrooj99's Avatar
Mrooj99
4wd High
Sorry for the delayed response, hopefully you can still assist in this.
I’m confused by your last response, so this happened while you were in tow/haul mode? You cleared the codes and haven’t had any issues since? Is that what you’re saying?
Have you used tow/haul since and did it do it again?
I was towing in tow/haul and started having similar issues. Truck acted like it couldn’t find the right gear when accelerating or stopping. Now I think it may be in limp mode and won’t shift past 3rd.
Im getting the exact same codes as you.
Old Nov 28, 2022 | 03:29 PM
joe blow's Avatar
joe blow
You might want to start a new thread rather than bringing back a 5 yo thread.
You may have better luck this way.
Greek 350
Mar 15, 2012 08:02 PM
tarditim
Oct 12, 2011 03:29 PM
twall_SD250
Mar 20, 2010 09:40 PM
steverowe
Mar 5, 2004 03:56 PM
