fuel sender problem
Old Jul 23, 2017 | 08:40 PM
car polisher's Avatar
car polisher
fuel sender problem
I replaced factory fuel sender ( filled tank and never registered full)
LMC send a new sender installed and while I put it I noticed I had about a quarter tank of fuel. When I started engine needle went all the way to FULL and the gradually went past E (not visible needle)! Any suggestions next!
Frustrated! This is on a 54 F100 (converted to 12 volt) replaced 239 Y block with a 351w and C6 transmission. Thanks!
Old Jul 24, 2017 | 01:55 PM
Connecticut Calvin's Avatar
Connecticut Calvin
Did you install your sending unit with fuel in the tank?! Holy moly you're brave.
Let's first make sure your gauge is OK. With the power of the truck OFF, remove the fuel take sender unit wire from the top bolt of the fuel tank and ground it to the frame. Turn to the key ignition to ON. The fuel gauge should peg full. If it does, you just verified that your fuel gauge is good.
Now, DRAIN THE TANK, remove the fuel gauge (carefully) from the tank. With the ignition off, install the sending unit wire to the top insulated bolt and then attach a new wire from the chassis of the truck (ground) to any one of the bolt holes that attached the sender to the tank. Now manually adjust the float with your hands. Your mimicking the fuel tank levels. Move the float all the way up. Does it show full on the gauge? What you just did is what we did with the earlier gauge test. It's basically like full-ground. Move it halfway down. Does the gauge show half? Sometimes the linkages have to be bent a little.
Old Jul 24, 2017 | 03:50 PM
tinman52's Avatar
tinman52
Welder User
What gauge and what sender?
If you are trying to use one of the repop/China/Vintique senders with the stock gauge it will never work. They do not match the gauge. Try to find an original or NOS FORD sender...
67Yeller
Nov 4, 2012 09:14 AM
TwistedFate
Jul 27, 2012 07:11 PM
grizzen
Sep 25, 2011 09:26 PM
stroken
18
Sep 29, 2009 01:48 PM
69f250mg
Aug 13, 2001 02:58 AM
