dead spark plug
Old Mar 26, 2004 | 01:27 AM
ktownford's Avatar
ktownford
dead spark plug
Hey there everyone I keep having a spark plug die on me in the same cylinder. My motor is a 390 4v, w/ headers no exhaust leaks plugs are autolite 45's as book suggested. Just curious as to what might cause this to happen and is there a better heat range plug to run. I curently still have points setup soon to be upgraded to.
ktownford
67 F700 dump 390
68 F250 4x4 390,
np435,np205,4"lift
35's
Old Mar 26, 2004 | 12:06 PM
Freightrain's Avatar
Freightrain
What does the plug look like when you take it out?? Sooty, wet, like new??
I take it the motor starts missing?? Does it use any oil?? Antifreeze loss??
Need to track down the symptoms to help with a diagnosis.
Old Mar 26, 2004 | 12:11 PM
Bob Ayers's Avatar
Bob Ayers
You may have a bad plug wire. To verify this, try switching plug wires with a different cylinder.
Old Mar 26, 2004 | 08:02 PM
Lobuck76's Avatar
Lobuck76
If ignition checks ok, it might be time for a compression check.
Old Mar 26, 2004 | 08:53 PM
sullyda1's Avatar
sullyda1
If your plug is oil fouled, for a temporary fix, try installing a spark plug that is a couple of ranges hotter.
