autolock hub not working
Old Jul 21, 2017 | 11:27 AM
ithaca1230's Avatar
ithaca1230
Well just replaced most everything in the front axle. Hubs, vacuum seal, dust seal, inner seals and calipers. I also cleaned the autolock hubs. Fist time I used them they worked. I tried again today and no 4wd. I checked the vacuum lines and they are all intact. Not sure what to do next.
Old Jul 21, 2017 | 11:29 AM
andym's Avatar
andym
Do you have a vacuum pump? Start looking for leaks.
Old Jul 21, 2017 | 11:46 AM
Stewart_H's Avatar
Stewart_H
Do they work when you manually lock them?
Stewart
Old Jul 21, 2017 | 12:06 PM
ithaca1230's Avatar
ithaca1230
Stewart
yes they work manualy. It is acting the same way it did before I cleaned them.
Old Jul 21, 2017 | 12:19 PM
Stewart_H's Avatar
Stewart_H
When you replaced everything, did you check the lines for leaks, like Andy suggested?
Stewart
Old Jul 21, 2017 | 12:23 PM
ithaca1230's Avatar
ithaca1230
I inspected them. I did not see any sign of damage. I do not have a way to test them that I know of.
Old Jul 21, 2017 | 12:32 PM
rock2610d's Avatar
rock2610d
Suggest you "T" off one of vacuum lines to hub with a vacuum gauge.
That will tell you if hubs are still leaking or if they are getting vacuum.
Easiest way to tell if hub is leaking is to blow into vacuum line to hub. If you cannot blow thru it's good. If you can is bad.
The gauge will also tell you if vacuum solenoid is working right or not.
Old Jul 21, 2017 | 12:33 PM
Stewart_H's Avatar
Stewart_H
What engine do you have? Your sig isn't showing.
If you have a 7.3L, turn your keys to the "on" position to power up your vacuum pump to fill the line. That will allow you to track down the leak.
Stewart
Old Jul 21, 2017 | 03:30 PM
ithaca1230's Avatar
ithaca1230
Stewart
sorry its a 2005 6L EB with too many upgrades to list
Old Jul 21, 2017 | 03:39 PM
Stewart_H's Avatar
Stewart_H
Not very up on my 6.0L knowledge, but it's still a diesel and it doesn't make vacuum so you have a pump. Turn the key to "On" and see if you can find the culprit after your pump turns off.
Stewart
Old Jul 21, 2017 | 05:38 PM
chetspencer's Avatar
chetspencer
Working Auto locking hubs on a Superduty / Excursion = Unicorn. Does anyone know if there's an aftermarket alternative Auto Locking Hubs. I don't mind getting out to lock my hubs but the wheel caps have to be removed to do so.
Old Jul 21, 2017 | 06:42 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I must have a unicorn. Mine work fine.
Old Jul 21, 2017 | 06:57 PM
chetspencer
I thought mine worked fine also. That is until I ran a AE code scan.
Old Jul 21, 2017 | 09:11 PM
Oldguyfl's Avatar
Oldguyfl
On my last ex there was a valve where the vac lines meet and go to the hubs. On a 7.3 its on the passenger side between the pump and the battery, high on the fender. Mine was bad, replaced it and they worked fine.
Its got two vac hoses and an electrical connector. Can't remember the name of it now, pretty cheap to replace too
Old Jul 21, 2017 | 09:29 PM
BBFarms's Avatar
BBFarms
Took one of Mike's suggestions and replaced vac lines with high quality silicone lines. Fixed my A/C and 4wd. Worth it for the $20 it'll cost ya in tubing.
