autolock hub not working
Old Jul 24, 2017 | 08:31 AM
ithaca1230's Avatar
ithaca1230
I'm gonna mess with this next couple nights. 4wd works if you lock hubs manually. When I had it on the lift they engaged. You could hear them click. When its on the ground they do not. Not sure whats going on. It was doing this about a year ago. It has always worked until then.
Old Jul 24, 2017 | 09:06 AM
thor363's Avatar
thor363
Did you replace the inner seal(s) also, not just the outer o-ring seal? Check vacuum at either side and see if you have vacuum generated properly. If not... vacuum pump or solenoid or lines. If so... check inner seals too.
Old Jul 24, 2017 | 09:27 AM
thor363's Avatar
thor363
Might need a cheap cigar to find it lol
Old Jul 24, 2017 | 02:51 PM
ithaca1230's Avatar
ithaca1230
I replaced al the seals. I smoke cheap cigars all day long will have to mess with it next few nights. I have to replace a oil hose from BPD remote cooler then mess with this again. Thanks!
Old Sep 6, 2017 | 07:59 AM
ithaca1230's Avatar
ithaca1230
Just a follow up. I tested the vacuum hoses and they were fine. Gave it to mechanic and he replaced a solenoid. Auto Hubs work like new!
Old Sep 6, 2017 | 08:17 AM
rock2610d's Avatar
rock2610d
That's great.
Keep an eye on your front though, I bought a cheap solonoid replacement and it worked great. After 2 yrs it allow 15 in hg to lock hubs in but only puts out 5 in hg for the 30 second unlock pulse.
My hubs need about 7 in hg to ratchet to unlock mode. I'm getting a oem unit this time.
Old Sep 6, 2017 | 09:16 AM
pgguru's Avatar
pgguru
Originally Posted by chetspencer
Working Auto locking hubs on a Superduty / Excursion = Unicorn. Does anyone know if there's an aftermarket alternative Auto Locking Hubs. I don't mind getting out to lock my hubs but the wheel caps have to be removed to do so.
I have two sets one the Auto lock works but they are seized and the manuals don't.. the other the manuals work but not the Auto "Know" they are locked if I get stuck.
Here is something I learned the Hard way.. If you can not move at all when you are stuck your fronts will not engage until you go about a half wheel turn.
I looked like an idiot last spring with my back end stuck on a Ice/snow bank in a parking lot and the fronts not engaging.. had to get a dodge give me a tug to get off the snow bank.
Old Sep 6, 2017 | 10:11 AM
ithaca1230's Avatar
ithaca1230
Thanks Will keep an eye on it
KC8QVO
Aug 22, 2018 01:32 PM
Tact
Dec 4, 2013 04:24 PM
yotazuki
Jul 14, 2009 10:29 AM
bigtorque
Nov 6, 2007 02:13 PM
Duksrule
Jun 14, 2006 08:06 PM
