Code Reader Says V6 but it's a V8. Defective or user error?
Old Jul 20, 2017 | 07:30 PM
NCHD's Avatar
NCHD
I'm trying to decide whether I should return the Inova code reader I bought for my '95 F250. Pretty sure I followed all the instructions. But the code reader said 6 cylinders when the motor is clearly a 351w V8. I did warm the truck up first. Anything I might have done wrong? Thanks.
Old Jul 20, 2017 | 07:40 PM
ChRoNo16's Avatar
ChRoNo16
could also be the wrong PCM, someone who switched engines may not have switched the brain.
or your reader is bad
Old Jul 21, 2017 | 06:09 AM
NCHD's Avatar
NCHD
When I look up the VIN a V8 is indicated so I guess I've got a bad reader! ;(
Old Jul 21, 2017 | 06:44 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Switched engines from what? They never put a V6 in these trucks.
Old Jul 21, 2017 | 08:24 AM
madpogue's Avatar
madpogue
^^^^^ Well, the thread title says V6, but the OP's first post just says the reader said "6 cylinder". I doubt any code reader could tell the difference.
Old Jul 21, 2017 | 09:38 AM
rla2005's Avatar
rla2005
Clean the pins in the data link connector then re-run the KOER tests. If it still reads out the truck has a 6 cylinder engine then remove the computer, open it up and look for signs of leaking capacitors.
Also note the part numbers on the computer case. We can help decode what it was designed for. Perhaps someone swapped in a 6 cylinder PCM for some odd reason.
Old Jul 21, 2017 | 07:07 PM
ChRoNo16's Avatar
ChRoNo16
thats what I mean, it shows as a 6 cylinder instead of an 8, OP look at the engine, how many plug wires are on the driver side of the motor? if theres 4 u know the code reader is messed up, if theres 3 your truck has had an engine swap.
Also how did u decode the VIN? I have found some sites before that mess it up
Old Jul 21, 2017 | 08:16 PM
blackbronco92's Avatar
blackbronco92
Pretty sure he knows he's physically got a 351.. Anyway, if the truck did have a 6-cyl. It would be the 300 inline, so you'd be looking for 6 plugs all in a row.
Old Jul 22, 2017 | 06:35 PM
NCHD's Avatar
NCHD
Ok, here's an update. I sprayed some electrical contact cleaner on everything and re-ran the tests. Now it tells me I have 8 cylinders. Something must have been dirty or not connected tightly because I get more trouble codes now than I did last time too. Thanks, guys.
Sorry for the confusion about the V6. The code reader doesn't say "V". It just gives a number of cylinders and I just stuck a V in front of it because I have V on the brain...V-8 truck, V-twin Harley...all I have are V's!
sg1099
1997 - 2003 F150
Dec 21, 2010 05:17 AM
97 HD
Nov 11, 2007 07:37 AM
