a question about transmission cooler hose
Old 07-20-2017, 05:57 PM
Matt Newby's Avatar
Matt Newby
Matt Newby is offline
i figure the answer will be no but it never hurts to ask. what i am wondering is if i can use clear vinyl tubing with the braided reinforcement as lines to a transmission cooler. i am replacing the factory cooler with a much larger one and was wondering purely for looks since the hose will easily be seen through the grill.
Old 07-20-2017, 06:13 PM
Shawn MacAnanny's Avatar
Shawn MacAnanny
Shawn MacAnanny is offline
No that's pvc/vinyl and it not rated for much more than 140f
Old 07-20-2017, 06:15 PM
Shawn MacAnanny
If you want fancy clear tubing you can use PTFE or PFA but for a 1/2" ID tube you're going to be talking $16+ a foot and it's usually special order.
Old 07-20-2017, 07:53 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,634 Likes on 1,097 Posts
What temperature and pressure is it rated for? And is it rated for petroleum applications? I suspect it won't work for all three of those reasons.
Old 07-20-2017, 08:02 PM
Shawn MacAnanny
If it's the pvc braided hose from Lowes im pretty sure it's 100psi max at like 90ft but I've used it to 40psi and 160f in a non engine related application. It's gets very soft
Old 07-20-2017, 09:37 PM
z31freakify's Avatar
z31freakify
z31freakify is online now
Received 1,203 Likes on 828 Posts
Try a hydraulic supply shop, I've seen clear hoses for hydraulic use, not sure what their ratings are tho.
Old 07-20-2017, 10:31 PM
Matt Newby's Avatar
Matt Newby
To answer multiple questions in one reply. yes it is like the stuff from the hardware store, how ever it has a pressure rating of 180psi. the working temperature is only 150 i think. it did state that it was chemical resistant but not proof. i figured it was a no go but thought it never hurt to ask. i will check the local hydraulic shop just for grins and giggles though. thanks for the quick answers.
Old 07-20-2017, 10:52 PM
Matt Newby's Avatar
Matt Newby
i was still looking and came across this stuff....any thoughts?
https://www.gvc.net/p/3389/size-18id-through-38id
Old 07-21-2017, 02:16 PM
Mark Kovalsky
It's way too low on maximum temperature. I would expect it to last a very short time as a cooler line.
Diamnd1
1999 to 2016 Super Duty
20
09-07-2017 07:34 AM
FSeybert
07-30-2010 08:27 PM
tubolove
06-01-2008 01:08 PM
fjones
09-29-2005 10:16 PM
ptt
12-16-2004 12:02 AM
Quick Reply: a question about transmission cooler hose
