Sponsored by: Real Truck
4 wheel drive not engaging
Old Jul 20, 2017 | 08:06 AM
artfuldodger's Avatar
artfuldodger
My 2011 f350 is not engaging 4wheel drive from the dash switch. When I turn it to either hi or lo it says "shift in process" but no 4 WD. It will engage manually from the hub lock, no problem. I know very little about 4wheel drive but am otherwise mechanically knowledgeable. Please help.
Old Jul 20, 2017 | 08:27 AM
thomabb's Avatar
thomabb
Diesel or gas?
Old Jul 20, 2017 | 08:38 AM
artfuldodger
Diesel 6.7 long box .
Old Jul 20, 2017 | 09:04 AM
thomabb's Avatar
thomabb
Have you checked / inspected the vacuum lines that run to the front hubs?
Old Jul 20, 2017 | 09:12 AM
thomabb's Avatar
thomabb
If you can disconnect a vacuum line that runs to the back side of the wheel hub, you should be able to feel vacuum when in 4X4 and no vacuum when in 2X4. Starting in 2011, the "pulse" ESOF hubs changed to constant vacuum hubs.
Old Jul 20, 2017 | 02:20 PM
seville009's Avatar
seville009
if you are saying that the 4wd works when you manually lock the hubs, then your 4wd is engaging properly. It's just that your hubs are not locking automatically.
You can either fix the hubs, or just manually lock them from now on. I just manually lock mine once the snow comes, and leave them locked until winter's over.
austinpowerz101
Nov 12, 2011 05:00 PM
jimbeam87
Aug 14, 2011 11:49 AM
fflt765
Sep 29, 2010 06:30 AM
SKFordF150
Offroad & 4x4
Jul 20, 2010 04:38 PM
THE KING
Oct 28, 2007 09:48 PM
