At least F100/150 and full size Broncos up to 1996. I've heard some Lincoln or caddy had that bolt pattern way back in the day. I don't remember what or when though.
i see that, these tires i'm selling are four wheel drive tires, thanks again, not sure why i put them on my 2wd 68, they are aluminum wheels(also selling), will put wheels back to normal original type of tires
vidaliaman the bolt pattern on your truck is the same as the early Jeeps. when Jeep came out with the Wrangler in 1987. they changed the bolt pattern. its the same as the Ford Ranger the small truck. 5 on 4 1/2. also the same as the early 60,s Ford Mustang.
1940/48 Ford/Merc Passenger Car wheels are 5 lug 5.50" bolt circle, but no FoMoCo car after 1948 has this pattern.
Additional 5 lug wheels on a 5.50" bolt circle: 1969/74 E200; 1975/2014 E100/150.
1960's/80's Lincoln wheels will either have a 4.50" or 5.00" bolt circle
I'm not that familiar with cattle-hack wheels, but I doubt any will work.
