ultraranger i watched this on you-tube this morning and was wondering if it would work on my 67 f-100. i know that on 67 f-100,s there are a lot of one year only parts. just like the 67 Mustang that i also have.
My Ford slide says 1967 Bumps should have 2 speed wipers. But 1967's have a 1967 specific wiper switch. I am assuming the wiring plug that fits in to it from the dash harness is different from 68/72. In order to add the Dentside intermittent wipers you would have to do some creative wiring adapting. The Dentside intermittent wiper wiring and governor (control box) just interrupts the dash wiring and the wiper switch. And adds a switch for intermittent wipers.
Yes, if your '67 has a 2-speed wiper motor, which it should. I have an intermittent wiper module/governor and switch from an '87 F150 in my '69 F100.
With the wiper switch in the off position, if it's turned 1 click to the right, the wipers will be on low speed. 2 clicks to the right is high speed.
If the **** is turned to the left of off, this will be in the variable/intermittent range.
You may have to move one wire on the governor side of the connector for the washer function but otherwise, this is a simple plug and play, after you shorten the shaft on the switch where the **** attaches.
I've done the intermittent conversion several times on bumps. It's plug and play. Some wire alterations will need to be done on the dents as they are wired a little differently and different pluggies I believe
