Accelerator pedal
Old Jul 18, 2017 | 08:03 PM
hdman6's Avatar
hdman6
Question Accelerator pedal
I replaced my pedal last August. Original lasted to 260 k So I replaced pedal and Maps sensor as well. I used ford parts. I just had the same issue again with the pedal. The usual step on pedal no response from engine then will sudden jerk and rev up. then dead again. So i cleaned it up with Electronic cleaner and blew it out. That it seems made it worse and it died for good after that. So i ordered another one. Received it today and all is good again. Dealer (Autonation) formerly Tously Ford said it had 2 yr warranty and would need to be tested to refund the $$. No problem there. So my question to anyone out there is Dos it seem odd that it failed so soon? It seems these are rebuilt because they want t core return. I guess you cant get a brand new one. Having a DP tuner and changing tunes shouldn't affect the pedal assembly would it? Also since i do have the adjustable pedals in my truck (lucky me) it cost 530 bucks. Local dealer wanted 1150.00 they are crazy. thanks Jeff
Old Jul 19, 2017 | 07:46 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
It does seem odd, but entirely possible especially if the part is no longer available as new.
73z28cam
Apr 24, 2018 11:34 AM
TwistedLefty
Dec 15, 2014 03:29 PM
harryball42
Jan 28, 2014 08:12 AM
n20
Mar 29, 2010 02:34 PM
Skweeker
General Diesel Discussion
Dec 20, 2005 09:10 AM
