fuel injection problems
Old Nov 13, 2001 | 05:41 PM
Greg01's Avatar
Greg01
Hi , I seem to have some fuel injection problems after trying to test out the front tank.
The front tank was never used by the original owner. Over the weekend I purposely let the rear tank run out of gas (probably my first mistke). I then flipped the switch to the front tank (w/gas in it) and nothing. I switched it back to the rear tank (with gas in it)and still nothing.
It seems to be getting fuel and I tried pouring a little down into the throttle body. It wanted to go over a few times but didnt quite make it around to starting.
Anyone here ever have a similer problem?
Old Nov 14, 2001 | 05:20 AM
Greg01's Avatar
Greg01
Hi folks, just wondering if anyone else has had this sort of problem.
I have a job to do with it Friday and although I went to highschool with my mechanic, he has six daughters to feed!
Old Nov 14, 2001 | 05:14 PM
Avanti's Avatar
Avanti
Letting the tank go empty will kill the fuel pump. The pump in the other tank is probably dead.When you switch tanks do you hear it start running. Have someone stand near it while you turn on the ignition switch. Good luck.
1992 F150 ext cab XLT duel tanks
Old Nov 15, 2001 | 12:19 PM
Greg01's Avatar
Greg01
Your right, thanks.
$130 to my old highschool buddy, inc pump and install.
I wont do that again!!!
Old Nov 15, 2001 | 02:47 PM
larry derouin's Avatar
larry derouin
brucers
Aug 26, 2011 07:03 PM
muddslingger
Jul 15, 2010 04:25 PM
old blue 90
Jul 4, 2009 03:19 PM
snowmannn
Jan 4, 2006 04:52 AM
spd70
Sep 11, 2002 01:01 AM
