Headers for a 390
Old Jul 18, 2017 | 01:20 PM
Coleton_henry's Avatar
Coleton_henry
Headers for a 390
What are y'all running header wise on your 390s? Going to convert my 360 to a 390 or get another one altogether and I'm going to put headers on it. ( along with some other things )
Old Jul 18, 2017 | 02:08 PM
wyrm73's Avatar
wyrm73
2WD or 4x4? I have whatever crappy ones came with the truck and have been looking for a good replacement for a while. Most of the long tube choices out there aim the collector straight at the transmission mount. And 4x4 gets the added joy of trying to pipe around the transfer case. I am still holding out hope of finding someone who makes a fenderwell exit header for the FE engines. The last one I knew of was Mad Dog and they don't show in their catalog anymore. The next best bet would be shorties from what I understand.
Old Jul 18, 2017 | 02:12 PM
Coleton_henry
1976 F-250 Highboy 4x4
Old Jul 18, 2017 | 03:24 PM
somethingclever's Avatar
somethingclever
I like the 16 gauge hooker's for an FE/highboy application.
Fit well and strong...plus slip-on collector instead of 3 bolt flange.
Old Jul 18, 2017 | 04:12 PM
gemutlich's Avatar
gemutlich
Well-recommended:
Headers for Ford, Mustang, Pinto, Bronco, Cougar, Ranger, exhaust parts for home built do it yourself automotive headers.
Keep in touch and let us know what you end up using, and what you think of 'em!
Old Jul 18, 2017 | 06:25 PM
HIO Silver's Avatar
HIO Silver
Sanderson 3/4-length headers.
Unlike long tubes, doesn't require jackin up engine to install.
... doesn't trap the starter either.
Have fun with the long tubes!!!
Old Jul 19, 2017 | 07:01 PM
PA74F250's Avatar
PA74F250
I have the Hedman Elite with the ball and socket collector. They fit fine and do not leak and are 14ga. Bad part starter is trapped.
Old Jul 19, 2017 | 11:56 PM
fordman67's Avatar
fordman67
I plan on the hedmans as well. Their flange is thicker than some of the other inexpensive units.
Old Jul 20, 2017 | 10:20 AM
9thPony's Avatar
9thPony
I'm using Stan's Headers. Excellent fit and finish.
Old Jul 20, 2017 | 10:49 AM
Roger Carter's Avatar
Roger Carter
Look for the header with the thickest flange and the heaviest gauge tubing and I doubt you will be disappointed. Note...They won't be cheap.
I have used Hedman Elites on numerous trucks, both 2wd and 4wd and have always been pleased with their fit and finish.
I have L&L on my own '78 4x4 (with a 460) and have no complaints whatsoever.
Good luck.
Old Jul 20, 2017 | 11:06 AM
Jonnyuma's Avatar
Jonnyuma
Are the Sandersons that much better than the Hedman Elite series?
I'm also on the lookout for new headers so info is being absorbed by more than the OP. I've considered shortys and fenderwell exit units... what's the best?
When I say "best" I'm mostly considering ease of install, fit, and longevity.... tuned for peak HP is not really a "thing" in this case.
Old Jul 20, 2017 | 11:44 AM
Roger Carter
Jonnyuma,
I can't speak as to a Sanderson header since I have never used them. I have read a lot of positive comments about them, as I have with Hedman Elites, and all my experiences with the Hedman Elite have been very good.
Shortys are usually an easier fit than long tube headers. Fenderwell exits are typically an easy fit, but they bring along their own set of problems when hooking up to the exhaust system.
Personal preference and experience have a lot to do with attitudes and opinions toward headers.
Hope this helps.
Old Jul 20, 2017 | 06:47 PM
jakeharp's Avatar
jakeharp
Budget
If your on a budget like I was, the Flowtech's worked fine and were very affordable.... FE390 Right around $200, direct fit for my collectors, so worked out nicely.... Part# 12542FLT for 4x4
BigBoy73
20
Feb 23, 2015 10:03 AM
heikks
Apr 22, 2009 02:52 PM
460man
Nov 5, 2006 08:40 AM
NWcountry
Mar 27, 2005 01:17 PM
390man
Exhaust Systems
Mar 4, 2005 01:16 PM
