Homelink door opener power source
I don't have my truck yet (mid-August delivery) but would like to know if the garage door opener is powered constantly or only when the ignition is on? The truck will be too tall for my garage so unfortunately it will be parked outside.
If it is "always on", has anyone swapped the power source? I have done this with previous vehicles but only those with the homelink buttons on an autodimming rear-view mirror (tapped into the auto-dim).
Thanks,
Steven
Thanks,
Steven
I've had vehicles of each type. I've never had a Ford so I'm not sure how they approach it. It is true that you do have to enter the truck to use it, but it is a bit like having the key to your house (or the part with good stuff anyway) sitting in a glass box on your driveway.
We could have some fun for sure.
I guess the upfitter switch wiring would be in the neighborhood. Maybe I could tap into that. It's one of those mods that just lets you sleep a little better.
For that matter, I guess I could just label one of the unused upfitter switches as "garage" and leave everything stock. That'd likely suffice around these parts.
I have the same concern, I actually programmed mine and reset it so it doesn't work anymore. My garage doors are tied to the house alarm and really don't want some idiot setting off the alarm thinking they are going to get in the garage.
on
A year ago renting a place I woke up one morning to find my garage door open and bike was missing.
What I found out was the guy was casing the place. The garage door had never been reset aka factory codes where still intact. So with some driving around with openers they found a garage that responded, mine. Neoghbors told me my garage door was open several times past few days when I was not home.
Anyways lesson learned change your codes if you can. ******* broke I while we where sleeping too good thing the garage doors are always locked.
GN1220
1999 to 2016 Super Duty
01-03-2017 04:30 PM
speedracer54729
04-24-2014 12:23 PM
