Sponsored by: Real Truck
CODE P0022
Old Jul 17, 2017 | 07:17 AM
Mark Bodner Jr.'s Avatar
Mark Bodner Jr.
CODE P0022
I have an F250 with the 5.4 V8. Its throwing the code P0022 and when I'm in reverse or idle after reverse it rattles and sounds almost like a crappy diesel. Has anyone ever had this problem before? Should I continue to drive it?
Ill try to upload a video of it before the end of the day
Any help is appreciated!!
Old Jul 17, 2017 | 07:22 AM
Chuck's First Ford's Avatar
Chuck's First Ford
P0022 Ford
link above for your code.
Old Jul 17, 2017 | 07:31 AM
Mark Bodner Jr.
I went and got the code scanned and found it's bank 2. I'm just wondering if anyone's had this happen to them before, how expensive is it to fix and should I keep driving it with the code and the shake in reverse or bring it to the shop?
Old Jul 17, 2017 | 07:57 AM
Mike1's Avatar
Mike1
I would get it fixed ASAP, if it's your DD. Why would you want to mess around with driving it and taking a chance on even more damage happening. The VVT or VCT sensor sends the signal to the ECM / PCM for timing adjustments on the engine, obviously, there is a problem with the solenoid or wiring. Remember one simple saying : A problem ignored will only lead to bigger problems down the road.
cole peters
Dec 20, 2011 10:03 PM
KHADIJE22
6.4L Power Stroke Diesel
Oct 23, 2011 08:40 AM
JoseFeli
Mar 4, 2011 09:52 PM
