Water leaking on driver side floor board
Hello I have a 1993 f-250 7.3 non-turbo standard cab. I walked out to my truck this morning to find the floor mat on the driver side to have water on it. As well as right by the door seal. I knew about the leak by the door seal but the other was new to me. I found two leaks one was the square plug above the hood latch cable on the firewall as well as where the hood latch cable comes through the firewall. Fixed both of those. Could this also be the leak on the floor mat? When I was spraying water on those areas it was not dripping on the floor mat. But it was also not sitting facing up a hill like it was last night when it rained. I also sprayed water on the cowl seal and the brake booster seal because I replaced the brake booster awhile back no leaks. Thanks
spongecop
05-12-2011 04:19 PM
Fordzilla80
06-19-2010 04:06 PM
