Keyless Entry Keypad Code Card
Old Jul 16, 2017 | 06:28 PM
F2502011's Avatar
F2502011
I need a replacement keypad code card and I can't find anyone that either knows what I am talking about or that can tell me how to get a replacement. I've contacted the dealer, Helm Inc (they do Ford owners booklets), Ford customer service, parts departments and even tried to contact the assembly plant but haven't been successful.
Can anyone point me in the right direction to get a replacement or new keypad code card? I don't even care what code is on it in fact I would prefer to get one that has a different code than mine vs an exact replacement although that would be nice to have too, because if another thief breaks in my truck and takes it, I could always change the code and they would never know the original one if I had a card with a "non-permanent" code. I will likely never leave it in the vehicle in the future though. I simply want a replacement to put with my owners booklets to go with the truck if/when I sell it.
If you don't know what I'm referring to, it's the plastic blue, white and black card that has the 5 digit "permanent access code to the "Keyless Entry System" (numeric keypad located on the outside of the vehicle)" on it. It's about the size of a credit card and is usually placed in the owners manual folder. Here are a couple of pics of what I am wanting.
Old Jul 16, 2017 | 07:26 PM
Flooringit's Avatar
Flooringit
You don't change the code you just add a new one the original is always in the truck.
Old Jul 16, 2017 | 08:39 PM
F2502011's Avatar
F2502011
Not what I'm asking but thanks
Old Jul 16, 2017 | 09:22 PM
Flooringit's Avatar
Flooringit
You need to reread your post. Cause in middle of second paragraph you state you can change the code. Your welcome
Old Jul 16, 2017 | 09:58 PM
F2502011's Avatar
F2502011
no you're missing the purpose and just don't understand. Simply looking for a replacement card.
Old Jul 16, 2017 | 10:02 PM
Cornbred's Avatar
Cornbred
I may be confused, but what's the point of just having a card even if it has the wrong code?
Old Jul 16, 2017 | 10:06 PM
F2502011's Avatar
F2502011
Think as long and deeply as possible about it and the answer will likely present itself.
Old Jul 16, 2017 | 10:34 PM
burgy's Avatar
burgy
Ease up OP.
scan the card or take a pic. Edit on a pc. Print on card stock. Done.
Old Jul 16, 2017 | 10:50 PM
Sleepyguy's Avatar
Sleepyguy
I do not have a clue what the poster is asking.
You want a new code because one you have is compromised then you need a new BCM.
If you want a replacement card with the same code aka don't know the original code. I would guess a dealer has to look it up.
The codes on the card are had written into the BCM and can not be changed by any powers we are aware of. Maybe manufacture can modify the BCM coding.
Old Jul 16, 2017 | 11:14 PM
tortue71's Avatar
tortue71
Go to a scrapyard and look for one in the glovebox ?
Anyway your question doesn't make sense because nobody understand what you want.
What is the point that of having a fake card ?
Old Jul 17, 2017 | 05:08 AM
bushpilot's Avatar
bushpilot
the master code (printed on the hard card, that comes in your owners manual/kit) is permanent and is part of the computer it can NOT be changed or erased.
the only way to change the master code is to replace the computer
as far as setting up some thief to steal the wrong card Im not sure I under stand the point - why not just remove the card from the manual set & lock it away in the house?
Old Jul 17, 2017 | 05:22 AM
BLUENGRAY05FX4's Avatar
BLUENGRAY05FX4
OP- do you know the original code? If so, why dont you just make up your own card and laminate it. If not, I've heard the code is actually on a label stuck to the trucks computer.
Old Jul 17, 2017 | 05:33 AM
burgy's Avatar
burgy
I believe the OP wants a put a card in his truck thats wrong so if stolen, the thief has incorrect info.
Old Jul 17, 2017 | 07:59 AM
KidAutolite's Avatar
KidAutolite
[QUOTE=F2502011;17332594]
Apparently there is a thief out there with your permanent code. Did he get your address or any personal information? Did this happen at home or a place you frequently park at? Did he do any damage to your truck? He could come back and use the code to get in.
Old Jul 17, 2017 | 10:11 AM
manowell's Avatar
manowell
This is what he wants it for, which I kind of understand. If I was buying a pre-owned truck and that card wasn't included I would kind of wonder why.
