6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
wont start
Old Jul 16, 2017 | 05:19 PM
semper0507's Avatar
semper0507
Question wont start
i have a 2010 F250 powerstroke we replace the high pressure fuel pump, bleed lines, checked ICP and glow plugs and it wont start.. pls help asap
i will take any test or things to look for if u have any idea
Old Jul 16, 2017 | 10:19 PM
jimh425's Avatar
jimh425
Will it start in neutral?
Old Jul 17, 2017 | 11:43 AM
semper0507's Avatar
semper0507
no it will not start in neutral
Old Jul 17, 2017 | 12:57 PM
Picton's Avatar
Picton
Is the starter relay/fuse good? We just had an issue with a section of wiring harness being faulty on one of our work trucks(6.4 PSD). We replaced the starter thinking it was the issue...then the truck wouldn't start at all...looked at the starter relay/fuse...which ended up leading to a wiring issue related to the starting system.
Old Jul 17, 2017 | 01:38 PM
speakerfritz's Avatar
speakerfritz
no start as in the motor does not spin or no start as in the motor spins but does not fire up.
a starter not spinning is an electrical problem
a motor not firing up if starter spins could be electrical, mechanical, or fuel problem.
mikels
17
Jul 21, 2021 12:08 AM
pwjackson42
19
Aug 24, 2016 07:29 AM
Whodatkid
Aug 14, 2016 08:57 AM
DENNIS VANSLYKE
1997 - 2003 F150
Jul 24, 2011 09:47 PM
dstacey
Jul 22, 2003 01:10 PM
