Anyone know what a complete failure on a water pump pulley looks like?
On Edit, Chris have you ever used the holes in the hub to keep it from rotating while you removed the fan? Asking as I remember when I first did that it took a lot of force. Those holes were put there for that purpose, but I'm now wondering if the pulley was designed correctly for the operating forces, just not with the foresight of the stress of in-service work. Once problems noticed, it was redesigned.
Punching that flat metal into a dished hub, and punching out the mounting holes, certainly can develop a lot of residual stress in the mounting area.
I used this tool.
not the easiest to use, but I didn't see any flex. Diesel Tech Ron has a video showing him using a chatter gun and chisel on the fan nut, not one of his best pieces of advice.
It doesn't matter if it's the common tool, screwdriver, pry bay or socket extention, there will be torsion to the pulley. One could argue the impact hammer has the least potential for distortion, but you'd need to strain gage the pulley to know that.
I used the common tool, broke its tip. Used a socket extension, still couldn't break the fan nut loose. Ended up doing the impact hammer and that worked. Since then the threads have been coated with antiseize and snugged only. Still can be tempormental.
I put blue locktite on the fan threads too. Gonna take a lot more effort getting it off next time, not being able to unscrew it most of the way by hand and all. But I'll sleep better not worrying about the fan unscrewing itself.
On the bright side, I did the Bullet Proof Diesel 7.3 fan clutch conversion a few months back, so now I can put a wrench on the adapter nut while unscrewing the fan nut with another wrench. That's an advantage nobody ever mentions. No more stress on the pulley, and no special tools. I guess I can take that spanner off my wish list!
Edit - I just remembered the bore in the pulley won't clear the corners of the adapter nut, so I will need the spanner if I need to replace the water pump.
That failure is common on the 03' and 04's! I had it happen to me.
The fan was on so tight that i had to pull the water pump, fan and inner shroud as one unit. I ended up cutting the pump apart, welding the flange to a welding table and had a buddy help me break the fan loose.
In all honesty I would recommend to replace the pump with an OEM one just for piece of mind! It is a sucky job to have to redo it.
Jennmiller1985
General Automotive Discussion
09-18-2018 07:17 PM
Restlesswildman
11-05-2013 09:58 PM
g0dl355
11-15-2009 06:38 PM
