Clicking
Old Jul 15, 2017 | 12:42 PM
marv02's Avatar
marv02
Clicking
The other day my 1997 F250 RWD started having a clicking sound coming for the front end of the truck sounded like left wheel bearing.
I jacked up the truck grabbed top of the tire and there was play replaced both side front wheel bearing.
Stated to back the truck out of the garage the clicking was still there.
The truck has 140K so I figured it probably a U joint.
I replaced all 3 U joints and center support bearing.
Backed the truck out of the garage and the clicking sound still there.
I tried to remove the hub caps did not work.
Any one has any idea what to look at next.
It sounds like a bad SpeedO cable only clicks when the tuck moving Forward or in Reverse faster truck moves faster the clicks Slower the truck move slower the clicks.
The only thing I can think of the transmission E4DO.
Old Jul 16, 2017 | 08:28 AM
Scndsin's Avatar
Scndsin
Rock caught in the tread of a tire?
Old Jul 16, 2017 | 12:02 PM
Azryael's Avatar
Azryael
This happened to me on my Wrangler once! I looked at everything.
It wasn't until I had someone drive it by me that I was able to pinpoint the noise to left rear tire where a decent rock had wedged itself so tightly into the treads that even high speed driving wouldn't cause it to fling out.
Your truck being a '97 also won't (or at least shouldn't) have a mechanical drive speedo cable.
Have someone else drive the truck by you and see if you can hear it better from an outside perspective as listening from inside the truck with the window down really won't do much for you.
Old Jul 16, 2017 | 01:17 PM
marv02's Avatar
marv02
It is a metallic sound not sound rock makes.
And I know there's no speed O cable but that what sounds like.
[Q toUOTE=Azryael;17331886]This happened to me on my Wrangler once! I looked at everything.
Have someone else drive the truck by you and see if you can hear it better from an outside perspective as listening from inside the truck with the window down really won't do much for you.[/QUOTE]
Old Jul 16, 2017 | 03:10 PM
Azryael's Avatar
Azryael
Hmm, metallic? Like pinging?
Old Jul 16, 2017 | 03:14 PM
marv02's Avatar
marv02
Update I put the truck on Jack stands started the truck put it in great to help pin point the clicking noise first had engage theE Bark because the wheels were turning to fast all I was getting a very fast clicking sound so slowed it down.
It from under the hood Left hand side against the firewall what I can figure out so far.
Old Jul 16, 2017 | 03:25 PM
marv02's Avatar
marv02
Found it bad aux fan relay.
seagiant
Dec 19, 2008 03:18 PM
TurboTuff
Dec 18, 2007 05:21 PM
mtgrzlyman
Sep 3, 2005 12:00 AM
hopscotch
Jan 7, 2005 07:15 PM
rrich600
May 25, 2003 11:26 PM
