Ford engine ID help
Old Jul 15, 2017 | 04:57 AM
drptop70ss's Avatar
drptop70ss
Ford engine ID help
Any way to find numbers on this engine to figure out what it is? Intake is a performer 390 so I know it is an FE, but how to tell what year and displacement? I know zip about Ford engines, just picked up another project truck and going to ID what I have here. Trans will be next to ID.
Thanks!
Old Jul 15, 2017 | 06:36 AM
harleymsn's Avatar
harleymsn
Try this http://ford-y-block.com/Block%20identification.htm
EDIT: this is why I should not post before having my coffee. Try this http://www.fordification.com/tech/ca...rs-FEblock.htm
Old Jul 15, 2017 | 06:41 AM
JPMallory's Avatar
JPMallory
This might help:
http://www.erareplicas.com/427man/engine/partnums.htm
Old Jul 15, 2017 | 09:43 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
FE engines are Y blocks, but most people either don't know this or don't call them that. 1954/64 Y blocks have the dizzy behind the carb. FE's have the dizzy in front of the carb.
Look on the block for the casting number and date code, once these are known, this will pin the engine down to one or two years. But it will not ID the size of the engine.
1958/64 FE engines were only installed in cars, have rounded valve covers without holes for smog valve/oil cap. There is an engine oil fill tube at the right front.
When people attempt to install these engines in 1965/76 F100/350's, they discover that the bolt pattern on the block is different where the rubber insulators bolt on, so they have to fabricate brackets.
1965/76 FE engines have pent roof shaped valve covers with holes for smog valve (right side) and oil cap (left side).
1965/71 Passenger Car & 1965/76 F100/350 use the same bolt pattern for the rubber insulators.
1958/67 352: Bore: 4.00" .. Stroke: 3.50."
1968/76 360 (F100/350 only) & 390 (1965/71 cars & 1968/76 F100/350) use the same block and heads, the bore is the same (4.05"), the stroke is different.
Measure the stroke to determine engine size. 360 = 3.50" .. 390 = 3.78."
Some FE engines have 352 cast on the block, but this is a foundry mark only. It is not the size of the engine! The cast 352 was replaced by a cast reversed 105 circa 1971.
Note: On sale day, 352/360's magically become 390's!
Old Jul 15, 2017 | 03:02 PM
drptop70ss's Avatar
drptop70ss
Numbers on the side of the block are D4TE, searches made it sound like that narrowed it down to a 360 or 390, then other sites list multiple displacements...so looks like that did not narrow it down much. I will look for more numbers once it is out, then it gets thrown up for sale.
Old Jul 15, 2017 | 09:56 PM
tinman52's Avatar
tinman52
Welder User
It's easy to measure the stroke thru a spark plug hole....I use a piece of stiff wire.
If it was closer I'd buy it.
If you part it out, I'd be interested in the intake manifold.
Old Jul 15, 2017 | 10:37 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Correction -- Police Interceptor 390's....
I think it was Tom McCahill who remarked (back in the '60's) that Ford changed the stroke on FE's at the end of every shift.
Shepting
Apr 5, 2019 09:56 PM
tcobra66
Jan 18, 2017 04:46 AM
HillBillyBuddha
19
Jan 7, 2013 09:41 PM
stromburg
Nov 14, 2012 01:58 PM
perra103
Feb 20, 2011 10:58 AM
