Sponsored by: Real Truck
Clutch Safety Switch Plug
Old Jul 13, 2017 | 08:11 PM
martinarcher's Avatar
martinarcher
Hello,
I've got a 2002 Excursion that was converted to a manual (ZF6 swap). I finally got the cruise figured out. I jumpered pin 29 on the PCM to the RD/YL wire off Connector 212 at the fuse box (hot when run). This tells the PCM the clutch is out. I bought a clutch safety switch and would like to wire it in so the cruise disabled when the clutch is pushed like the factory pickups. The Excusions were not built with the clutch switch plug like the auto trucks since they were not ever offered with a manual.
Anyone have a wrecked truck they wouldn't mind cutting the clutch switch plug out of? I'd be happy to buy one off someone that has one. I've got the wires run just need to tie them into a plug.
Thanks!
Old Jul 15, 2017 | 08:01 AM
The Bone's Avatar
The Bone
If you cant find one check Rock Auto or go to a dealer. You may have to match it to the trans.
Old Jul 15, 2017 | 03:56 PM
martinarcher
Beleive it or not I think I found it on Amazon. Dealer wanted $62, local yards want $50+ and can't give me a straight answer if they have one or not. $38 shipped on Amazon....and it's the Motorcraft part.
Tdracer344
Aug 14, 2016 04:24 PM
Thedonk
19
Sep 22, 2015 07:39 AM
MSC1
Jan 14, 2007 11:15 AM
FatzFord
Mar 11, 2004 09:56 PM
raeandjim
Oct 28, 2003 01:19 AM
