Changing Fender Need Help
Old Jul 13, 2017 | 08:46 AM
Fordication's Avatar
Fordication
I have a 93 F150. I pulled a fender off of a 96 Ford 350 but it does not appear to match when installed on my Truck. Is there a difference or should I just buy a new fender and get on with it?
Old Jul 13, 2017 | 08:51 AM
Benztechnc's Avatar
Benztechnc
AFAIK they should be the same. What doesn't match? Can you show us with a pic?
Old Jul 13, 2017 | 03:42 PM
rla2005's Avatar
rla2005
1992 to 1996 F150/Bronco and 1992 to 1997 F250HD/350 all use the same body panels.
Old Jul 28, 2017 | 09:08 AM
Fordication
Thanks guys.
Old Jul 31, 2017 | 12:48 PM
Fordication
Ok so the body shop claims that the fender did not fit so they bought a new one from a parts store. This one does not fit so they are claiming that a 0 mile per hour bump my daughter gave the front fender when she scratched the fender pulling out of a Sonic must have bent the frame. Funny thing is that the old fender fit perfect prior to taking it off. In fact the lines were spot on and the truck has never been wrecked. I noted that there are 2 bolts on the old fender in the center. Are these used to pull the fender in because there is a 1/4" gap on the front fender sticking out from the door and the fender is 1/4" off on ever gap including the hood and window. The hood is 1/4" higher than the fender and I refuse to pay until they get it right.
Old Jul 31, 2017 | 02:00 PM
Roger T. Pipe's Avatar
Roger T. Pipe
Are these Ford or reproduction fenders?
Old Jul 31, 2017 | 07:35 PM
Fordication
Here are photos of the salvage fender that they tried to install. The new one looks a little bet better than this. What did they do wrong because this is a factor fender I pulled off of a truck that was in great condition. Thanks
Factory fender that does not fit.
This is the best they said they can do but it is even lower that its supposed to be
Almost a 1/2" gap, Truck never wrecked. There has to be an adjustment these guys are not making.
Old Jul 31, 2017 | 08:42 PM
wharthog's Avatar
wharthog
There is a bolt inside the fender that you get to from the door jam area while the door is open. That fender looks like it needs some shims on the top and the center bolt installed inside to be tightened while putting pressure on the outside of the fender pushing inward.
Take time to see what all the adjustments will do to the fender and you can get it real close.
Good luck
Old Jul 31, 2017 | 08:49 PM
wharthog's Avatar
wharthog
Also, when you push the fender inward it will go up some.
Old Jul 31, 2017 | 08:51 PM
Fordication
That is what I thought. So there is a bolt that can be used to pull the fender in?
Old Jul 31, 2017 | 09:18 PM
wharthog's Avatar
wharthog
Yes there is a bolt that "holds" the position of the fender once aligned. Open the door, get down low so you can see past the hinges, look between the two hinges, with a flashlight you should see a protruding mount extending from the inner lower A pillar or the side of the cab. there is a mating flat edge that should overlap and a J-nut with a bolt holds the fender position when tightened. It is hard to find at first but once you locate it you will see how it is supposed to work and it will make sense.
Old Aug 1, 2017 | 02:07 PM
Fordication
Thank you. now to get the body shop to do their damn job.
Old Mar 12, 2019 | 04:31 PM
subford's Avatar
subford
Top image:
Second image above:
McGiver
1978 - 1996 Big Bronco
Aug 17, 2013 08:28 PM
hilltd69
Feb 23, 2008 04:59 PM
Captbo2001
Jan 16, 2005 04:47 PM
a_turbo_stang
Sep 26, 2004 10:45 AM
Katt
Apr 22, 2000 08:10 AM
