Questions about RABS
Old Jul 13, 2017 | 07:42 AM
y2kc0wb0y's Avatar
y2kc0wb0y
Hooray - first post!
Talking 1991 F250 5.8L 4X2.. trying to fix basic sinking pedal issue.
Questions about RABS....2B373 is the Ford part # in the manual, but I'm seeing a lot of OEM valves that have 2B373-x something on the end. for Example 2B373-HRM or 2B373-A. I cannot find a reference to the trailing information. Are these manufacture updates or do I need more specific information before purchasing?
Trying to decide re-man valve or OEM.
Does the forum gods recommend a re-man or do you recommend going with one of the updated OEM valves? On eBay the price is around $200/$250 depending.
Thanks for your time.
P.S. "Checking OBDI codes (EEC-IV) " link is broken in the technical sticky post.
Old Jul 13, 2017 | 02:55 PM
Lead Head's Avatar
Lead Head
What makes you think it's the RABS valve causing your sinking pedal?
Old Jul 13, 2017 | 03:06 PM
tjc transport's Avatar
tjc transport
i ain't rite
the extra letter is nothing more than the number of the update to the part number.
before wasting money on an ABS valve, try bypassing it to see if it is in fact the problem.
Old Jul 13, 2017 | 03:46 PM
y2kc0wb0y's Avatar
y2kc0wb0y
Thanks for answering my question about the part #.
I guess I should say low pedal not sinking pedal.
I've replaced the pads, rotors, master, drums and shoes so far. I've followed the bleed procedure as recommended on this forum RR, LR, RABS, FR, FL.
I've also adjust the boost rod into the master cylinder.
Given that not sure what else it could be?
Old Jul 13, 2017 | 04:18 PM
y2kc0wb0y's Avatar
y2kc0wb0y
I will re-bleed the entire system again and make sure the rear are adjusted until just a slight drag is notice. FYI: My E-brake is excellent and under hard braking I get rear wheel lock. IDK; feel like this low spongy pedal thing isn't really answered directly on the forum
I tend to throw money at the problem.
Old Jul 13, 2017 | 05:23 PM
tjc transport
i ain't rite
the master cylinder on the 250 is too small and usually gives "that sinking feeling"
BUT bypassing the RABS valve most of the time eliminates the sinking pedal.
i guess as they get old they fail internally and bleed off pressure.
the abs on my 88 has been bypassed since the truck had 400 miles or so on it. the dealer could not figure out why i would just loose brakes and run red lights, and then ten seconds later hit the brakes and kiss the windshield. so they tried bypassing the abs and the brakes were perfect. and have stayed that way ever since.
the only vehicle i own that has ABS is the 2014 superduty. all 9 of the others either never had ABS, or it was been disabled as soon as i got it
Old Jul 13, 2017 | 05:59 PM
KULTULZ's Avatar
KULTULZ
Question
The dealer by-passed or disabled the ABS on a new veicle with 400 miles and you accepted it...
Old Jul 13, 2017 | 10:43 PM
Dean06919's Avatar
Dean06919
1997 F350 master cylinders have larger bores and provide better performance. May want to swap it while you are at it.
Old Jul 14, 2017 | 07:12 AM
tjc transport
i ain't rite
they wanted to order a new RABS valve, but since everything i have ever driven before that and since until i got the 2014 in january has never had abs anyway, so it was not a big deal to have a new vehicle with working brakes.
Old Jul 14, 2017 | 12:02 PM
y2kc0wb0y's Avatar
y2kc0wb0y
Kinda confirms my thoughts on the RABS. I guess it begs the question are the updated valves any better?
Old Jul 14, 2017 | 03:48 PM
tjc transport
i ain't rite
probably not.
Old Jul 14, 2017 | 09:41 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
There's a lot of bad information out there about these trucks but this is about the goofiest bunch of BS I've ever heard.
Old Jul 15, 2017 | 06:11 PM
Azryael's Avatar
Azryael
I'm glad you took the time to provide some actual useful info as well!
Old Jul 17, 2017 | 09:33 PM
y2kc0wb0y's Avatar
y2kc0wb0y
True; Kinda off topic but the valve update was the question and reman or OEM
Old Jul 17, 2017 | 11:03 PM
HardScrabble
https://www.ford-trucks.com/forums/3...ellow-red.html
This links to the best information that was out there twelve years ago. It's mostly all gone now. I posted to to a thread recently that was as good as it gets now. Even idiots need good brakes.
