Washer fluid setup
Old Jul 17, 2017 | 12:27 PM
JEFFFAFA's Avatar
JEFFFAFA
Originally Posted by lunar68
I don't see in your pic where the water goes IN your pump.
Old Jul 17, 2017 | 12:49 PM
lunar68's Avatar
lunar68
Yeah, it looks like it's missing that inlet filter that goes into the reservoir and holds it in. I'll probably just have to a new pump along with the reservoir.
Old Jul 20, 2017 | 12:40 PM
grantorinosport's Avatar
grantorinosport
Personally, I'd use the 1971/79 F100/350 & 1978/79 Bronco reservoir (D1TZ-17618-B-reproduced) and its pump.
Question: Does the mounting of this reservoir interfere with the forward portion of the driver side inner fender such that a second battery install would be impeded?
Currently my 71 has no reservoir, so I'm not sure what it is actually supposed to look like. I know kinda where it is supposed to go, but up in the front I'd like to throw in a second battery someday in the future.
Old Jul 20, 2017 | 12:47 PM
pchelp's Avatar
pchelp
Just saw this on DC
Windshield Washer Reservoir | Dennis Carpenter Ford Restoration Parts
Old Jul 20, 2017 | 01:31 PM
cranemec's Avatar
cranemec
I don't have a close picture but this is where it goes. Bolted to the fender.
Old Jul 20, 2017 | 01:34 PM
JEFFFAFA's Avatar
JEFFFAFA
And this at DC.
1968 -70
C8TZ-17618-A
0 Star
$24.95 ea
Old Jul 20, 2017 | 01:38 PM
grantorinosport
So the plastic reservoir, recommended by NumberDummy, and correct for my 71, would mount in the same location as your reservoir "bag" cranemec? If that is the case, that would definitely not get in the way of a second battery.
Old Jul 20, 2017 | 01:41 PM
JEFFFAFA's Avatar
JEFFFAFA
This bag type was 1965/1967.
Old Jul 20, 2017 | 01:52 PM
JEFFFAFA's Avatar
JEFFFAFA
Or you can do what I did with a 1994/97 T-Bird/Cougar washer reservoir. My 68 was missing it's wiper reservoir also. I just happened to have a 97 hail damaged Cougar to swipe parts off of. It's reservoir had the motor in the bottom side of it. So I just clipped the wiring off the Cougar along with the reservoir. There was the 2nd horn in this location. So I snagged the dual horn assembly off the Cougar and mounted them in place of my Bump's right side horn.
Burnt Rubber
Jul 20, 2018 10:19 AM
ford_maniac-68
Feb 9, 2017 06:35 PM
WILDMAN_Stroker*7.3
Aug 19, 2008 08:16 PM
asavage
Aerostar
26
Feb 8, 2008 04:05 PM
